1st Gen R53 Cooper S Power/starting issue
Discussion in '1st Generation: 2002–06 R50, R53 & 2004–08 R52' started by lr19, Oct 15, 2016.
  1. M1N1
    M1N1 Well-Known Member
    Jan 5, 2014
    726
    329
    Tool and Die Maker
    NW Ohio
    On an Amazon listing, they will give a "used" option alongside the new price. I have tried this several times, and received an item that is new and unused, but in an open box. I got an AC compressor that way, new and unused, for $155 shipped. Just something to look at.
  2. lr19
    lr19 New Member
    Aug 12, 2016
    54
    Problem has been fixed! Ground wire on engine wasn't connected
  3. Dave.0
    Glad that was an easy fix, but you still may want to do the plugs, coil and wires as a little diy project.
  4. 00Mini
    Quite possibly you may want to check/replace your gas tank fuel pump filter as ten years and 176,000 miles is long time.
  5. lr19
    lr19 New Member
    Aug 12, 2016
    54
    For sure, that's deff on my list I'm slowly getting his car back to shape, previous owner didn't seem to do much maintenance at all
  6. lr19
    lr19 New Member
    Aug 12, 2016
    54
    Is that on the frame rail? Is it inline?
  7. ZippyNH
    In the tank...under the rear seat....
    If the prior owner usually kept the tank mostly above 1/4 it might be fine....
    If the filter is of unknown age, might be worth doing that....
    Just run the fuel level down low, and it won't be too messy.
  8. lr19
    lr19 New Member
    Aug 12, 2016
    54
    Gotcha so pretty easy access? I never knew those seats folded up
  9. MCS02
    It should be the same for 02-06 most R53's use the same parts.
  10. M1N1
    Jan 5, 2014
    726
    329
    Tool and Die Maker
    NW Ohio
    Apart from the items already mentioned, it would be a good idea to do a coolant flush, change the brake fluid, replace control arm bushings with Powerflex (if not done already), serpentine belt, check suspension/drive components (ball joints, strut mounts, wheel bearings, etc), tranny fluid, etc. Basically any maintenance that you don't know when it was done last. I know that it sounds like a lot of things to do, but a MINI is not like a Honda or Nissan. It will all help to keep you car on the road. :Thumbsup:
  11. Dennis Bratland
    Dennis Bratland New Member
    Aug 28, 2016
    34
    Stay at home dad
    Ballard, Seattle
    Mod Mini has this covered.
    [ame="https://www.youtube.com/watch?v=rCppUQfNZQQ"]Replace Fuel Filter - Gen 1 MINI Cooper R50 R52 R53 - YouTube[/ame]
