Powerflex Control Arm Bushings Installed -- now I hear a clanking noise when braking.
Discussion in 'MINI' started by Baby, Jan 7, 2010.
  1. Baby
    Baby New Member
    Nov 29, 2009
    10
    Hi All,
    So, I got new PowerFlex bushings b/c my OE bushings were shot after 50+K. Neighbor installed them, and he is a master at anything to do with fixing cars. So, lots of confidence in him.
    However, last night when returning home as I was driving around my neighborhood, I noticed a small metal on metal noise (a small tap or clank) each time I pressed the brakes. It's not loud or too serious sounding, but noticeable. It happens just as your press the brake petal, not when releasing or during the press -- just the beginning of the press.
    He said it's most likely because the new bushings (PF in brackets) are stiff in comparison, and there is little to no give.
    Anyone ever have this issue and is this a concern I need to address?
    Thanks
    Steve Robert
    I'd be more inclined to think a caliper is sticking.
  3. Ryephile
    Ryephile New Member
    Apr 9, 2009
    299
    122
    Yes!
    Metro Detroit
    Agree with Nathan, it sounds more caliper related than bushing related...unless your buddy forgot to torque down the front control arm ball joints or another fastener. Does the car drive normal otherwise?
    I run the Madness front control arms which have spherical bearings [metal sphere, no bushing at all] and I get no noise in normal street driving. If this setup isn't noisy, solid polyurethane certainly shouldn't be. Have your installation checked.
    Ryan
  4. Dr Obnxs
    Dr Obnxs New Member
    Jun 11, 2009
    1,158
    Sounds like something is loose
    or the caliper issue mentioned. The powerflex can't have a metal-metal hit.
    Matt
  5. Way Motor Works
    Way Motor Works New Member
    205
    MINI Tuner
    Atlanta
    Check to make sure everything you took off to do the bushings is tight.
  6. Mike
    Mike New Member
    Totally agree. Even the masters leave a bolt loose once in a while.
  7. OSUBeaver
    OSUBeaver New Member
    May 15, 2009
    29
    Hillsboro/Portland, OR
    A quick check might be the tension spring on the caliper, easy piece to forget to put back, and you can see if it's there through the wheel. I backed out of the driveway with it off once and heard a similar noise.
