1st Gen R53 Cooper S Procedure for changing car battery
Discussion in '1st Generation: 2002–06 R50, R53 & 2004–08 R52' started by ChItalian1027, Jan 19, 2016.
  1. BruceK
    BruceK Active Member
    Feb 24, 2015
    Texas
    I've got an early '02 and my car has gone almost a week with no battery hooked up. Didn't lose a thing other than the clock time and the trip odo reset to 0.
    I can't imagine how misguided you'd need to be to remove a battery from a running car.
  2. beken
    beken Well-Known Member
    Jan 13, 2010
    1,405
    1,829
    Delta, BC
    My 1999 Buick (GM cars) had a code in their radios also. If you don't bother setting it up, the code from the factory is 0000. If you change it, you have to let your mechanic know what you changed it to, or you have to enter the code yourself. Otherwise your radio (and clock) won't work.
    Honestly, I have no idea who would want to steal a factory radio. GM Delco or Honda's OEM especially.
  3. Ernesto
    Ernesto Club Coordinator
    May 16, 2009
    701
    763
    Oracle DBA
    Skokie Ill
    If you need help, let me know.. I've done 2 in my Cooper, and dont live too far away..
  4. Razone23
    Razone23 Active Member
    Nov 3, 2013
    175
    27
    technical support
    nothern CT
    LOL
  5. BruceK
    Feb 24, 2015
    Texas
    I wonder if, somewhere out there on the Interwebs, someone is likewise recommending on doing an oil change while the engine is running.
    After all, the oil will be warm and will drain well. :biggrin5:
  6. DneprDave
    I always do oil changes with a cold engine. All the oil has run down into the oil pan and doesn't have far to go to drain out. If the engine has been running, the oil is all over the inside of the engine and will drip for hours before it is all drained out.
    Heck, our modern low viscosity synthetic oils aren't very thick when cold anyway.
