Professors R53
Discussion in 'Car Builds, Projects, Idea's Experiments' started by Professor, Mar 19, 2011.
  1. BThayer23
    That's what Dan at Grassroots recommended for my 06 with a factory LSD. It feels thin for the first couple hundred miles, then it kind of settles in. I'm not sure if there's a perfect fluid out there.
  2. Professor
    Professor New Member
    69
    BMW / MINI tech
    Kentucky
    Yea it was not the consistency I thought it would be. Got it swapped out and test drove. Got a chance to test the LSD out of DSC. Pulled out onto a road covered in dirt from a construction project.
  3. Professor
    69
    BMW / MINI tech
    Kentucky
    Haha all that work and I just purchased an 06 Getrag with LSD on the cheap :).
  4. CrazyIvan
    CrazyIvan New Member
    Jul 1, 2009
    31
    Is that the factory lsd? I pulled one of those out when I swapped trans and put in the torsen. H@ll anyone interested in a factory LSD?
  5. Professor
    69
    BMW / MINI tech
    Kentucky
    Yup thats the OEM unit.
  6. Professor
    69
    BMW / MINI tech
    Kentucky
    Got the Gen5 M45 installed as well as the facelift Getrag with LSD. No chance to do a full test drive yet.
  7. mimini1
    mimini1 New Member
    Dec 2, 2009
    104
    11
    Does that make you ready for Cookie?:Thumbsup:
  8. Professor
    69
    BMW / MINI tech
    Kentucky
    LOL his Mini will always be one of my fav's.
    He was going to come out and help me put the trans back in but he was busy. Had to use the engine hoist to get it in there.
  9. Professor
    69
    BMW / MINI tech
    Kentucky
    No big performance changes really. Need to update a bit I guess.
    Pics of the Gen 5 Eaton. All oil removed and replaced. Also removed the snout for inspection and sealed.
    NS1 cam installed but no images. Love this cam BTW.
    Installed R56 rear trailing arms.
    TCE 6 pistons and ST rotors
  10. agranger
    I've been using Redline MTL in my '06 MCS w/ factory LSD for around 50-60k miles. Works great for me.
  11. ScottinBend
    You don't find it a bit "thin". I ran it in mine for a little over a year and went back to OEM cause it didn't feel as smooth.
  12. agranger
    Ever since I put on the short shifter, my shifting feels a bit 'thick' (but I like the shorter throw enough to not let it bother me). Anything that makes it a bit slicker is good for me. Honestly, I chalked up any slight change in feeling to the freshness/cleanliness of the fluid... never did a side-by-side comparision of clean MTL vs. clean OEM close enough to each other to be able to tell any appreciable difference.
  13. BThayer23
    I agree that it's a bit thinner, but not necessarily something I dislike.
  14. Cone Assassin
    Cone Assassin Local Shop Owner
    Jan 7, 2012
    65
    17
    Wow, the last couple pages look a lot like my thread :)
    Are you sure you can use a GL-4 in your trans? My Clubman has the factory LSD, and recommends using a Texaco MTF-94 IIRC. Using a GL-4 may reduce the effectivenes of the OEM LSD.
    I also ran the GL-4 in my R53 getrag (open diff) and it was hard as hell to shift. Switched to Amsoil Synchromesh and love it. Also I have converted every VW 02J and 02M from my co'workers cars with Synchromesh and they all love it. Not saying it would work best with a factory LSD. For a stock getrag with an open diff, that is my recommendation. :)
    Great build, will be following :smile5:
  15. Professor
    69
    BMW / MINI tech
    Kentucky
    I dont notice it effecting my trans or diff. Shifting is still nice and smooth and the LSD works as it should during wheel slip.
    I have always been under the impression that GL-4 is the preferred fluid for the Getrag and LSD? Maybe I am wrong?
  16. Cone Assassin
    Jan 7, 2012
    65
    17
    GL-4 is the spec fluid for the much heavier Audi Quattro transmissions. It may be okay with the LSD Mini trans, but as far as I know it does not have the additives to keep the diff functioning properly as in the MTF-94 (or so says Mini).
    Let us know how it works out in the long-term. It may be a good solution for the LSD equipped cars with poor shift feel. :beer
  17. k-huevo
    k-huevo Club Coordinator
    159
    Pipe Creek, Texas
    #57 k-huevo, Mar 31, 2012
    Actually, MTF-94 is a GL-4, and it is often used to fix noisy OEM LSDs, which can groan at wheel lock. MTF-94 is the specified fill for the first generation.
    MTF-94 (a GL-4) has a very sophisticated and robust additive package. I spoke to Terry Dyson about the transmission lube, and he knew quite a bit about its development by Texaco; he tested a 30,000 mile change interval from my gearbox, with excellent results.
  18. jiminni
    jiminni Well-Known Member
    262
    Ca.
    That could also be due to the fact that there is less "leverage" with the shorter shifter?
  19. Cone Assassin
    Jan 7, 2012
    65
    17
    Thanks! Did not know they were one in the same, good information :smile5:
  20. theCapn
    theCapn New Member
    May 13, 2009
    98
    Upstate, SC
    Anyone that is following this thread, and Professor in specific, can you comment on the changing of the rear trailing arms from the R53 steel, to the R56 aluminum ones?
    Did you notice a difference? Worth it?
    I have a pair lined up, at a steal/deal, but want to get feedback before I pull the trigger.
