Professors R53
Discussion in 'Car Builds, Projects, Idea's Experiments' started by Professor, Mar 19, 2011.
    Have you seen this article in the library?
    I think it was worth it, the rear is easier to rotate as there is a bit more movement in the bushing.
    As to being lighter, I can't feel that.
  2. theCapn
    theCapn New Member
    May 13, 2009
    98
    Upstate, SC
    Thanks, I did read that... albeit right after it was written.
    After reading it again, I think it would be worth it.
    Thanks for the help!
  3. Msfitoy
    Msfitoy Member
    May 16, 2009
    123
    19
    Automotive/Industrial Designer
    NC
    Most awesome Mini :Thumbsup:
  4. Professor
    Professor New Member
    69
    BMW / MINI tech
    Kentucky
    Thanks brother! But I think yours is at the top of my list ;).
    I have some updates in a few days :)
  5. Sneedspeed
    Sneedspeed New Member
    Jul 16, 2009
    165
    56
    Racing cars
    Pfafftown NC
  6. Professor
    69
    BMW / MINI tech
    Kentucky
    15x8 make Brakes look HUGE! But I have a little work to do for a tad more clearance ;). But nothing to bad.
  7. UKCoopeR
    UKCoopeR Active Member
    May 21, 2009
    293
    109
    VA,USA and UK
    I agree, very race car, great choice on the 15x8 pf-01s and wilwood brakes, though I am biased :smilewinkgrin:
    It took me a bit of spacer measuring (to clear the barrel, spokes had plenty of clearance) but definitely worth it :yesnod:
  8. Professor
    69
    BMW / MINI tech
    Kentucky
    I got lucky. Only a 5mm spacer was needed.
  9. UKCoopeR
    May 21, 2009
    293
    109
    VA,USA and UK
    Cool doesn't cancel any signficant amount of the weight saving then :) and should still be in the fenders unlike mine haha
    I run 5mm on the rear for the wheel (stock brakes back there)
    I have to run 20mm on the front to fit the custom wide discs which does add some weight, but worth it as i have a lot more confidence as this set up has yet to fade (thanks Todd!)
    my 16x7 for rain/street don't need any but don't look quite as f1 either
  10. Professor
    69
    BMW / MINI tech
    Kentucky
    Fit the tires today. With the R56 rear trailing arms on, I had to remove a small amount of casting material at the lowest point to clear the wheel. I ended up with a 5mm spacer in the rear and 8mm up front. I may bump up to a 10mm up front.
  11. minsanity
    minsanity Well-Known Member
    Sep 11, 2009
    581
    352
    #71 minsanity, Sep 16, 2012
    Wow! Post more pics fr all angles, pls!:Thumbsup:
  12. Dave.0
    Nice picture and choice of wheels. I have a set also.:Thumbsup:
    Man those wheels look so good. To me those 15 inch wheels just look so right & proper!
  14. Professor
    69
    BMW / MINI tech
    Kentucky
    I will get a few more shots in the drive today. Can't go far as I had to give my pcv valve to a friend to get his mini down the road.
  15. Professor
    69
    BMW / MINI tech
    Kentucky
  16. Nathan
    Purrrrty wheels!
  17. Kahnfucious
    Kahnfucious New Member
    Sep 7, 2012
    #77 Kahnfucious, Nov 21, 2012
    sorry -- realized that was a GP front..nice build though.
  18. Professor
    69
    BMW / MINI tech
    Kentucky
    What are you sorry for?
  19. itsmewutup
    itsmewutup New Member
    Apr 11, 2012
    351
    67
    He originally asked how it was a JCW front on it.
