Pump gas... which is the best octane?
Discussion in 'MINI' started by Forkboy, Feb 7, 2012.
  1. AllPepperS
    AllPepperS New Member
    Jan 20, 2012
    35
    9
    Dog Nanny
    Palm City, FL
    I have used BP93 since I got the Mini a couple of months ago and then they put a new Sunoco in closer and I "believe" I could feel a difference in the 2. I read this post and have discovered there is a station 2 miles from me behind a Shell and a Pure Station near the turnpike that sells no ethanol pure gas. Went down there and they were great, they said all the hot rods and super bikes fill up there. So I am trying it :biggrin5: I still had a 1/4 tank and I am going to check it by hand and see what the scangauge comes up with to see how big an improvement I get after a tank or 2. It is more expensive by about a nickle to the 93 at Sunoco, came out to about $4.12 a gal. I am in Florida.
    Tracy
  2. Metalman
    I just filled up with Sunoco 93.... :D
  3. Cappi Gal
    Cappi Gal New Member
    Mar 21, 2012
    19
    LA, CA
    By looking at this, i realized I know nothing about gas. My car is on the boat and should be delivered to me next week. I have always used Chevron, is there any difference between Chevron and Shell? Which one should i use? Any help for this soon to be Mini user would help.
    Thx.
  4. Redbeard
    1,636
    398
    Glorified spreadsheet jockey.
    #24 Redbeard, Mar 22, 2012
    Either is fine. They both produce gas with detergents. The octane (87/89/91 generally in CA) of the gas is most important. Use 91 (since you are in California like I am that is all you will find generally) or 93 where available (since you are in California like I am 91oct is all you will find generally) for best performance. IIRC This is "Strongly" recommended in the manual. :Thumbsup:
  5. Cappi Gal
    Mar 21, 2012
    19
    LA, CA
    Thanks for the help!!
  6. Austinsynthetics
    109
    44
    California
    Increasing octane above 91/93 and carbon build up...
    After reading about the carbon build up in the MCS 07 and others, would an octane boost help to prevent the build up? OR, is there a risk of engine damage on a stock engine?
    Thanks for the info
  7. r34king
    r34king Member
    Aug 18, 2011
    71
    34
    Auto Tech NTB Capital BLVD
    No. Octane booster wont help. They are a direct injection engine. By witch the injectors don't spray on the intake runners and valves, so there is nothing cleaning the backs of the valves like you get in a regular fuel injected engine. Your best bet would be use 91 or 93 (whatever is available) and sea foam your intake once in a while.
  8. iwashmycar
    iwashmycar Active Member
    Jun 1, 2009
    881
    87
    architecture
    These links are great. Lately I have been consulting the Ethanol Free site before filling up. There are very few stations around me sadly, but I have found one close and they have been getting all of my business. :cornut:
  9. Firebro17
    Looks like the only "pure gas" stations are in Northern CA. That Figures...
    Great info though.
  10. ScottinBend
    Just be careful with these unbranded fuels as they will not have any kind of additive package in them.
    When I can I just get a half and half fill up so I can get the Chevron Techron.
  11. iwashmycar
    Jun 1, 2009
    881
    87
    architecture
    Isn't that a good thing? :confused5:
  12. Redbeard
    1,636
    398
  13. dr61
    dr61 Member
    Oct 9, 2011
    30
    6
    Redding, CA, USA
    FYI in California at regular commercial stations (excluding a few specialty outlets requiring card-key access and a few racetracks), all gas is identical except for the additive package. The additive is mixed in at the station, so the fuel truck can come from any California-spec refinery.
    For instance, a Chevron station could be refueled from a truck carrying gas from a Shell refinery, but then the Chevron additive package is mixed in as the fuel is pumped out of the truck. This info is from a Chevron refinery engineer I'm related to.
    On the subject of altitude vs octane, for the non-turbocharged models (including the supercharged R53), octane requirement will go down somewhat with altitude. Not so much with the turbocharged models, which can maintain boost at near sea-level pressure because the turbo can spin faster at higher elevations.
  14. grodenglaive
    grodenglaive New Member
    Apr 3, 2010
    313
    68
    Ottawa, Ontario
    all the additives are good for you:smile5: - they're there to help to keep crud from building up, among other things. That's why the manual recommends you use tier 1 gas only like Shell, Chevron.
    It still doesn't prevent the carbon problem unfortunately.
  15. ScottinBend
    Additives, like Techron, are a good thing. They keep things nice and clean and running smooth.
  16. iwashmycar
    Jun 1, 2009
    881
    87
    architecture
    Gotcha. I still feel that unbranded ethanol-free is going to be better in the long run than Techron 10% ethanol.... Not sure it that is at all true, but it is my current mind-set lol.... I could be wrong in my case too, since an FJ has no exterior fuel filter...it is in the tank with the pump... Thus it may also be more beneficial to have the CLEANEST gas possible, regardless of ethanol content.
  17. ScottinBend
    You can always add a can of Techron, or whatever, to your tank at fillup with the unbranded stuff.
  18. Jabbles
    Jabbles New Member
    24
    HVAC service
    Sarnia, Ontario, Canada
    I try and fill up in Michigan when I can, gas is pricey here currently $1.44 liter(roughly $5.45 gallon) I have recently paid $70 for a fill up.
    I do have access to 94 Octane though.
  19. minijack
    minijack New Member
    Nov 26, 2009
    OK, being frugal and all, can I mix the local 89 mid grade with the 93 high test?
  20. Nathan
    Why mix, they sell 91 at the pump.
