1st Gen R50 R50 French hillclimb championship build
Discussion in 'Car Builds, Projects, Idea's Experiments' started by PascalR50, Mar 30, 2020.
  1. PascalR50
    PascalR50 Member
    Feb 12, 2020
    40
    64
    First operation launched for MINI project .
    208 kg remove of the daily car at this stage .
    All interior plastic take off , simplification of electrical harness ,take off ventilation and air conditioned .Rear and front chest cylinder. aibag , ABS ,internal and exterior miror , all heat protection of exhaust line , etc.......
    i think 25 kg could be remove for the end of project ( light flywheel / alloy rear arms.) but not more.
    After you need to change specific parts like doors / hood / windows but the cost will be increase.
    • Roll cage is ordered ,
    • kit Getrag 6 gearbox is in preparation in UK .
    • JCW challenge coilover are ordered (used).
    Now i must wait end of CORONAVIRUS mesure to receipt all parts .
    I cant continue to prepare welding body due to lack of welding material ( Most of supplier are closed in France)
    See you later
    I never knew a “Justa” R50 could make it up a hill.
    I'm sure it will do just fine. Pretty neat project. Nice to see a MINI going to be used in competition & not just droning back n forth on some road. ;)
    • Agree Agree x 2
    • Like Like x 1
  4. old81
    Nice project, should do fine if you can get all the power to the wheels. Going to upgrade to a FWD system from an old Countryman ALLwheel?
    Enjoy and go slow until you have it done right.
    • Agree Agree x 2
    • Like Like x 1
  5. MCS02
    6,315
    That a lot of wiring! Good luck. I can’t wait to see this project unfold.
    Stay well
  6. 00Mini
    2,259
    Looks like a great start to a very interesting project.
  7. PascalR50
    PascalR50 Member
    Feb 12, 2020
    40
    64
    Hi , no possibility to change to FWD system , this project is under special rules of french championship base on 2WD ( possible to change model of gearbox , but no possible to swap to 4 WD , same for the engine , need to keep 1.6 engine no possible to swap to turbo or compressor.)
    In the coming year FIA rules must be change to open rules for all parts without restriction .
  8. wmwny
    4,040
    2,242
    Would it be possible to have an ecu tune put on the car? I had one put on my R50 by Jan [Revolution Motor Works].
  9. PascalR50
    PascalR50 Member
    Feb 12, 2020
    40
    64
    Yes it is possible , change ECU or remapping of the stock ECU .I dont know yet which solution ...
  10. Dave.0
    Remap not change the ECU.
  11. wmwny
    4,040
    2,242
    Jan does a great job and my R50 has never run better.
  12. PascalR50
    PascalR50 Member
    Feb 12, 2020
    40
    64
    Hi , what type of remap do you have perform : Lauch control ? Ignition cut during shift ?Whith stock engine ? How many HP ?
    Sorry for my several question , i try to learn regarding experience of MINI owner .
    Pascal
  13. wmwny
    4,040
    2,242
    You should contact Jan @revolutionmotorworks.com for information. You can also tell him that we, of Motoring Alliance recommend him, if that helps you. I believe Dave.O also has his contact information. Jan has worldwide experience and a reputation. Dave.O put me in contact with Jan and that lead me to my first ECU tune with him on my R53, and later on my R50
  14. Dave.0
  15. colinmini
    colinmini Well-Known Member
    441
    Sadly, I never got too much help from Jan with an R50. He looked at my map down at the Dragon, but felt like what he had wasn’t going to be too helpful for what I was doing with my R50. Understandable, just not a lot that can be done to gain that much more power. As most people tell me, get an “S”! Lol. I’m sticking to my slow Justa just the same.
  16. Dave.0
    Suspension and good breaks are better mods for an R50. You can keep the speed you make in the corners and break later into the turns.
  17. wmwny
    4,040
    2,242
    #17 wmwny, Apr 1, 2020
    • When did you talk to Jan about your R50? I had the ecu in my R50 done by Jan while at MOTD about 3 years ago. It had an ecu on it by another vendor and Jan felt it was outdated after having checked it out, and installed his own [a newer and more efficient one].
  18. colinmini
    441
    It was a few years ago at MOTD too. Jan looked at my map, felt that he didn’t have anything better. He was going to do some addition research.
    Suspension and brakes are very important with making better time thru curves! I am running nothing all that unique, but it along with Colin Chapman’s Philosophy of “adding lightness” has made my little R50 pretty quick. Also, a LOT of driver instruction and LOTS AND LOTS of practice! Would I love more hp? Hell yes! Are there any easy gains for the R50, not so easy(or inexpensively)
    But the 240 Z, it’s all coming together! 793C3CAB-3226-4077-BFB0-E640F3E5E613.jpeg
    • Like Like x 4
    • Agree Agree x 1
  19. colinmini
    441
    Here is my lightweight door opening strap. Eliminated The heavy door handle and tweeter speaker! Lol. Ok, maybe not that much weight, but when you are counting ounces......
    • Like Like x 2
    • Funny Funny x 1
  20. PascalR50
    PascalR50 Member
    Feb 12, 2020
    40
    64
    Thank you for your answer for ECU mapping .
    Today i work on rear cradle and arms and i have some questions :
    I will change 2 arms of the rear cradle for 2 adjustable arms ( for lower position ) and therefore keep 2 original arms, on the other hand the upper and lower are not identical:
    * 1 kg for one / 1.5 kg for the other
    * Reduced silenbloc freedom / silentboc with more mouvement
    * Possible twist / more rigid
    Which should be kept better?
    Thank you
