R50 rough idle and limp mode
Discussion in '1st Generation: 2002–06 R50, R53 & 2004–08 R52' started by Delacruz25, Oct 15, 2020.
  1. Delacruz25
    Delacruz25 New Member
    Oct 15, 2020
    So I have an 05 MC and recently the car has had a rough idle. Morning cold starts are fine but once the car reaches operating temps, it starts to have this rough idle. I had two codes, P0302 and P0128. I changed the distributor cap, plugs and wires. Seemed like limp mode got worse. I’ll be sitting at a red light and check engine flashes and when I accelerate, it struggles to get going. I’m thinking it could be the crank pulley but need a second opinion.
  2. 00Mini
    2,264
    The first code is misfire on cylinder 2 and the second code is thermostat related. On the misfire I would check the coil and then if that was good a compression / leak down test. For the P0128 check the coolant level, thermostat housing and thermostat. I’m just an old shade tree mechanic and my knowledge is limited but those are the areas I would start. Hopefully it will be something easy and you’ll be up and running at full strength in no time.
    • Like Like x 1
    • Agree Agree x 1
  3. MCS02
    6,317
    Welcome to MA!
    • Like Like x 1
    • Agree Agree x 1
  4. minsanity
    minsanity Well-Known Member
    Sep 11, 2009
    581
    352
    Check fuel rail pressure & coolant temp sensor. The former, if low, could be fuel filter or pump related
    Sent from my SM-G970F using Tapatalk
