1st Gen R50 Cooper R50 trans swap impressions
Discussion in '1st Generation: 2002–06 R50, R53 & 2004–08 R52' started by daviday, Apr 23, 2014.
  1. RallyMini370
    if you decided to fix the midlands I have a several input shafts.
  2. daviday
    daviday Active Member
    Jan 15, 2014
    140
    25
    Chris, the midlands with the broken input shaft is the box that I sent off to Jon Waterhouse. Thankfully I don't need to replace the trans or even open it up. The issue was a broken drive shaft. I have to stop being so dramatic and pessimistic I guess.
    Thanks again guys and sorry for posting prematurely.
      File size:
      1.3 MB
      101
  3. BruceK
    BruceK Active Member
    Feb 24, 2015
    Texas
    Well, that sucks. But much it's easier to deal with than a transmission (and cheaper too!)
  4. RallyMini370
    Wow how did you break that!
  5. daviday
    Jan 15, 2014
    140
    25
    I really have no idea. It was replaced less than 3k miles ago. Replacing with an feq part. Hopefully it doesn't happen again.
  6. BlimeyCabrio
    Just a boot, right?
  7. RallyMini370
    looks like the boot. left side axle? did the boot split or the axle come out?
  8. daviday
    Jan 15, 2014
    140
    25
    Yup, left side. Hopefully it's still at the shop so I can take better pics. The actual cast piece closest to the joint shattered and the joint fell apart/out.
    After typing in FEQ mini, I'm not convinced this won't happen again either. Saving the receipt for this one but the other was put on not so long ago because the stock piece was worn and causing horrible vibration. This didn't make so much as a sound before it broke.
  9. daviday
    Jan 15, 2014
    140
    25
    Has anyone broken one like this?
      File size:
      695.6 KB
      101
  10. RallyMini370
    What part broke? I give my axles some serious abuse and have not broke one...yet
  11. BruceK
    Feb 24, 2015
    Texas
    Wait. An Chinese-made replacement axle at about 1/3 the price of a new OEM one isn't very good?
    Shocked, I am.
  12. RallyMini370
    I just know now I'm going to break an axle!
  13. Metalman
    Maybe....
    But the great thing is.... It won't be difficult to figure out what happened...
    It'll cut your "figuring" time way down....:eek:
  14. RallyMini370
    That's what I like about mechanical stuff. Electronics' that's another story!
  15. MCS02
    What, Chris, your great at electronics. I bet if you ever had a problem with electronics it would only take you 6 months to find it.............maybe.:biggrin5:
  16. RallyMini370
    cheeky bugger lol
  17. daviday
    Jan 15, 2014
    140
    25
    So I overlooked something. What do you guys think of this?
