ALTA Intercooler Air Diverter(with riveted/modified air inlet) and intercooler mister-$125. New ALTA silicone intercooler coupler boots in black-$35. MINI Cooper S 8 new intake valves(11 34 7 513 019)-$160. MINI Cooper S 8 new inconel exhaust valves(11 34 7 513 020)-$250. MINI Cooper/Cooper S toggle switch panel(with DSC and front fog lights)-$50. New ALTA Rear Control Arm Heim Joints(4 of them-enough for 2 control arms)-$80. Parts below came off a running 60K mile MINI Cooper S: MINI Cooper S Engine Wiring Harness-$100. MINI Cooper S Rocker assemblies with shafts-$150. MINI Cooper S Fuel Rail, Fuel Pressure Regulator and Stock Fuel Injectors-$150. MINI Cooper S Oil Filter Housing(with oil pressure sender and cover)-$100. MINI Cooper S Heat Exchanger/Oil Cooler-$50. MINI Cooper S Ignition Coil with spark plug leads(leads at 2.5 to 4.5 Kilo Ohms)-$50. MINI Cooper S Cam Sensor(1/2 of connector stop broken)-$40. MINI Cooper S Timing Chain Tensioner-$30. MINI Cooper S Water Pump(impeller good, seals good and no leaks out of weep hole)-$50. MINI Cooper S Supercharger Input Duct(no cracks present)-$40. MINI Cooper S Supercharger Output Manifold to intercooler-$75. MINI Cooper S Intercooler Output Manifold to intake manifold-$75. MINI Cooper S Intake Manifold-$125. MINI Cooper S Intercooler Brackets-$30. MINI Cooper S Throttle Body-$100. MINI Cooper S Bypass Valve(spring not broken)-$50. Contact me at [email protected] if you want info and photos. Thanks! Jeremy
Yes Jiminni there's no rear fog light toggle in this switch panel. Sideways I'm parting out this motor is all. Still have the breakdown and inspect remaining bits. Jeremy
Updated List ALTA Intercooler Air Diverter(with riveted/modified air inlet) and intercooler mister-$125-SOLD. New ALTA silicone intercooler coupler boots in black-$35-SOLD. MINI Cooper S 8 new intake valves(11 34 7 513 019)-$160. MINI Cooper S 8 new inconel exhaust valves(11 34 7 513 020)-$250. MINI Cooper/Cooper S toggle switch panel(with DSC and front fog lights)-$50. New ALTA Rear Control Arm Heim Joints(4 of them-enough for 2 control arms)-$80. Parts below came off a running 60K mile MINI Cooper S: MINI Cooper S Engine Wiring Harness-$100-SOLD MINI Cooper S Rocker assemblies with shafts-$150. MINI Cooper S Fuel Rail, Fuel Pressure Regulator and Stock Fuel Injectors-$150-SOLD. MINI Cooper S Oil Filter Housing(with oil pressure sender and cover)-$100. MINI Cooper S Heat Exchanger/Oil Cooler-$50. MINI Cooper S Ignition Coil with spark plug leads(leads at 2.5 to 4.5 Kilo Ohms)-$50. MINI Cooper S Cam Sensor(1/2 of connector stop broken)-$40. MINI Cooper S Timing Chain Tensioner-$30. MINI Cooper S Water Pump(impeller good, seals good and no leaks out of weep hole)-$50. MINI Cooper S Supercharger Input Duct(no cracks present)-$40. MINI Cooper S Supercharger Output Manifold to intercooler-$75. MINI Cooper S Intercooler Output Manifold to intake manifold-$75. MINI Cooper S Intake Manifold-$125-SOLD. MINI Cooper S Intercooler Brackets-$15. MINI Cooper S Throttle Body-$100-SOLD. MINI Cooper S Bypass Valve(spring not broken)-$50-SOLD. Jeremy
