Interior 1st Gen R53 Dash vents wont change
Discussion in 'Tuning and Performance' started by martabo, Dec 24, 2012.
  1. Guest - Welcome to the new Motoring Alliance Site! Steve, MCS02 and I were up until the early hours this morning working to get it done... as you can see it took us a bit longer than expected to get Phase 1 up and running. We are not 100% there.. its a journey. For site updates, "How Do I" and feedback please use the Announcements, How Do I, Feedback Forum (Links below). Like building a car.... its never done... and thanks for your patience
    Site Announcements "How Do I" Feedback
  1. martabo
    martabo New Member
    Nov 28, 2012
    70
    13
    Parts jockey
    2002 mini s. Air vents will run on defrost, and dash, but not on the floor.
    Are these dashes vacuum controlled, or electronic, and do i have to tear everything apart just to find out whats going on with it?
  2. rkw
    rkw New Member
    428
    Do you have auto climate controls, or manual?
    With manual controls, the vents are purely mechanical. The control knob is physically attached to a cable that pulls on the vent mechanism. If you try to look from the passenger side under the dash and behind the center stack, you can see what happens when you turn the knob. However, to find the actual cause of the problem, I think you'll have to take a lot of things apart.
  3. martabo
    martabo New Member
    Nov 28, 2012
    70
    13
    Parts jockey
    No, its a digital temp select
  4. 1momini
    1momini New Member
    Feb 19, 2013
    102
    46
    mechanical contractor
    Arkansas
    Noticed this today as well . Air flow won't switch to floor. Must not be common thing since this thread went dead. Any ideas? It's seem like the inside temp sensor may be going bad. Blows heat until its turned way down to like 60 degrees.
  5. Waltguy
    Waltguy New Member
    Apr 10, 2017
    Having the same problem on 2011 Cooper
    HVAC will act normal one day then can't select where air vents. Has anyone figured out this issue? Ours has Auto Climate Control. I'm going back to search the forum, any help would be appreciated!
  6. Firebro17
    3,318
    It's only a big deal in the Winter.
