1st Gen R53 Cooper S R53: Dead in traffic
Discussion in '1st Generation: 2002–06 R50, R53 & 2004–08 R52' started by shub, Apr 14, 2015.
  1. shub
    shub New Member
    Nov 16, 2014
    13
    Battery is brand new , I replaced it a few weeks ago when I first started troubleshooting my starting issues. Anyone want to buy a MINI ? The engine runs nice ;)
  2. shub
    shub New Member
    Nov 16, 2014
    13
    Is there anywhere in particular that water likes to sneak into causing electrical havoc? Like I said, the first few hours after I installed the alternator, all was peachy. Later, there was a big thunderstorm and I was driving through a lot of rain. Not sure if there's any relation.
  3. 05r50
    05r50 Well-Known Member
    Dec 4, 2010
    1,269
    696
    What year is your R53?
    There are some weird gremlin stories out there. For example on certain model years there is a spot on the firewall that rubs the harness and causes a hard to find short that tricks many people into replacing the body control module when it is actually a short in the harness.
    Maybe this will trigger some of the brainiacs here on where this might be coming from.
  4. shub
    shub New Member
    Nov 16, 2014
    13
    Built May 2005
  5. Canusrufis
    Canusrufis RMW Powered R53
    210
    107
    Winston Salem NC
    Were you able to test the alternator? And with the pump removed (circuit wise) does the problem still exist?
  6. shub
    shub New Member
    Nov 16, 2014
    13
    I have not tested the alternator yet. I parked two days ago after unplugging the power steering pump, but still experiencing the odd gauge dancing. Then yesterday, I went out to try driving it again- but th battery was utterly dead. There must be an additional parasitic draw, or perhaps the battery was pooched from the pump going as long as it had the day before . Anyhow, battery is trickle charging , I'll update once I put it back in the car
  7. Firebro17
    Test the battery. The trickle might not be enough to revive it if it was already headed south.
  8. Savvy
    THIS.... the bolded text above. Maybe Eric@helix or Herbie-53-guy can help point you towards this gremlin. They took care of Blake's MINI two years ago at the dragon when it had a bunch of electrical gremlins. Turned out to be this harness short.
  9. shub
    shub New Member
    Nov 16, 2014
    13
    Yes, I'd like to know where to look for harness chafing.
    I have not driven it to an auto zone to have the alternator tested, so far I'm too weirded out by the Christmas lights and ding dong sounds. But the pump is UNPLUGGED, and there are still plenty of gremlins.
    DSC light comes on intermittently , brake light, ABS light, tire pressure light , air bag light , service engine light. Lights come On/off, ding dong, sometimes even has intervals of seeming perfectly fine. The gauges also peg themselves randomly then go back again , similar to what happens when you do an ECU reset.
    When I did my first voltage test with car running , my probes were on the battery terminals. I decided to do a second volt test, between the positive terminal in the engine bay, and the large ground terminal on the motor mount. My readings were 13.4v to 15.25v, up and down, all over the road, never steady. Does this confirm the voltage regulator is kaput on my BRAND NEW, not even a reman, alternator ?
    It's worth noting a second time :
    1. The old alternator was seized due to the housing having cracked in half.
    2. After installing the new alternator , I had no electrical gremlins for a solid 3 hours of driving.
    3. Is it possible the continuous draw of the steering pump fried the previous alternator to the point of cracking ? And now it has fried the new alternators voltage regulator?
