Engine Drivetrain 1st Gen Cooper S R53 Headers
Discussion in 'Tuning and Performance' started by BSTINS, Jul 3, 2012.
  1. beaner
    beaner New Member
    44
    it is so nice to see people playing nicely!
    We all can play together, mod and motor. We can all share tricks of Mini ownership with each other.
    For example :
    I use a Sears electric leaf blower (150 mph) to dry / remove all the water hiding in little places after I wash. It works great under the hood after a SimpleGreen motor wash. It's also great at getting water from around the taillights, side vents, mirror caps, upper,mid and lower grills and all the door seems. I just unplug the vacuum when I am done and use the blower after I wash the car. It also helps cut down on the amount of MF towels I have to use when drying my car.
    In regards to headers you get what you pay for. Either $900 header (RMW or Mynes) is better than any sub $200 eBay or OBX header.
    If you are going to get a header buy a good once, put it on and enjoy it for a long time.
  3. 90intherain
    90intherain New Member
    Sep 17, 2010
    San Antonio, TX
    +1. Spend a little more and get something that will last. Do some research and learn about engine flex and it's affects on headers. I found out the hard way and broke the flex pipe on a expensive cost cheap made Madness header. Later I had the flex pipe moved to solve the issue.
