MINI R53 New owner
Discussion in 'Starting Line - New Member Introductions' started by guitos, May 19, 2019.
  1. guitos
    guitos New Member
    May 19, 2019
    12
    #21 guitos, Jun 8, 2019
    All the ground wiers are connected.
    Still no spark on the plugs.
    To recap, You have changed the crank position sensor, checked and all grounding straps are clean and tight, all fuses are good, and the only code you have now is the P1617. Is this correct?
    I know we talked about the coil pack, did you already replace it? also is it an OME?
  3. guitos
    guitos New Member
    May 19, 2019
    12
    Hi.
    Coil pack replaced but still no joy...
    Im running out of options... maybe i need to take the car to a repair shop..
  4. MCS02
    I am not sure what to tell yo to try next. If you take it to a shop let us know what they find. It may help some other Mini owner.
  5. guitos
    guitos New Member
    May 19, 2019
    12
    Hi.
    The car is in the shop since this morning and now the mechanic have called and still no clue of the problem, every time he connects the reader give different error codes.
    I'll keep all of you posted on further developments.
    Regards
  6. 00Mini
    Just random thoughts but does the coil have voltage input and is the crank sensor actually sending a signal.
  7. Sully
    Sully Administrator
    Jul 21, 2015
    Software
    30350
    How is this going?
  8. guitos
    guitos New Member
    May 19, 2019
    12
    Finally ready after all this time and 600 paid in shop. :eek:
    A problem with the fuse box that have disconnect the fuel pump and the coil.
  9. 00Mini
    Good to hear that you’re up and running now.
  10. o2sys
    o2sys Active Member
    May 20, 2019
    101
    161
    At least you figured it out. Wonder what cause it.
    Sent from my iPhone using Tapatalk Pro
  11. MCS02
    Glad you found it but I know the 600 hurt.
  12. guitos
    guitos New Member
    May 19, 2019
    12
    The mechanic told me that sometimes due to corrosion the connectors on the bottom of the fuse box stop working properly.
    Lets see for how long for now..
    Thank you all for your messages and help, much appreciated.
  13. Sully
    Sully Administrator
    Jul 21, 2015
    Software
    30350
    Interesting, hadn't heard of that. Good to know. Glad your back up and running now.
