Brakes Wheels 1st Gen Tires Most liked posts in thread: R53 widest square tire setup
  1. Eric@Helix
    Eric@Helix New Member
    1,257
    Shepherd
    Philadelphia
    Go 16" max. You might even be able to get away with 15" wheels if you don't have a BBK. If you're going as wide as 8" wheels, you'll have to check offset to be sure you don't rub too much. My policy is to let others be the guinea pig. Look around the internetz and see what others have done.
  2. Savvy
    Some info from a similar topic on another board... link to online tool at the bottom.
  3. jeffster06
    jeffster06 Active Member
    Apr 23, 2010
    420
    111
    Dallas, GA
    Should check out some 949 racing 6ul's clear the stock brakes fine and wilwoods with a spacer.
  4. UKCoopeR
    UKCoopeR Active Member
    May 21, 2009
    293
    109
    VA,USA and UK
    Tire options (for aggressive tires anyway) will be more plentiful in 15 if that matters to you.
    Those look TE37-esque which is a pretty solid style imho :Thumbsup:
  5. ColinGreene
    ColinGreene Well-Known Member
    438
    293
    Orange county Ca
    Pm the guy who owns the car and ask? You could always run R56 cooper brakes, same caliper smaller rotor and bracket to accommodate barrel size.
    I still dont encourage you to copy someone elses car though.
  6. MrBlah
    MrBlah Member
    Jun 19, 2015
    114
    I have stock brakes and am considering 15's
  7. MrBlah
    MrBlah Member
    Jun 19, 2015
    114
    ps I searched around a bit for what offset people run on 16's and that led me to post here
  8. MrBlah
    MrBlah Member
    Jun 19, 2015
    114
    those are growing on me, but they do look almost the same as the rims I already have
  9. MrBlah
    MrBlah Member
    Jun 19, 2015
    114
    really looking at these whatever they are, in 15" or 16"
  10. UKCoopeR
    May 21, 2009
    293
    109
    VA,USA and UK
  11. MrBlah
    MrBlah Member
    Jun 19, 2015
    114
    the kosei KR2 looks almost the same, not sure if they make it in a 15 with the right offset
    here's what I have now, wanted a style that is different
  12. ColinGreene
    438
    293
    Orange county Ca
    a RPF1 fits the car in 16x8 and you can put R56 brakes under it with a 225 tyre on the car.
    that should be plenty.
    Look for that gray car on Mini torque under DOMO, Though its amazing to me how many people want to copy that car.
  13. MrBlah
    MrBlah Member
    Jun 19, 2015
    114
    ahh I see he has rota wheels, 660 $ with a 20mm offset
    #Bronze GRIDV 16x8.0J
    #Hankook RS212 in 215/45 R16
    #Stud conversion with Muteki SR48 Steel Nuts
    16x8 Rota Grid V Wheels 4x100 Rim 20mm Offset Hyper Black | eBay
    17 pounds a tire, the 15" K2R is quite a bit lighter, 13.5, not sure if they will clear R56 brakes though that's what I will probably end up with
  14. MrBlah
    MrBlah Member
    Jun 19, 2015
    114
    he does not run 15" K2R's I'm not sure what asking him would do for me, what do you mean copy someones car? That makes no sense unless you buy custom rims cut just for your car there is always someone else that has the same rims as you do
