2nd Gen R56 Cooper S R56 High Pressure Fuel Pump Warranty Extension
Discussion in '2nd Generation: 2007+ R55 through R61' started by Metalman, Aug 13, 2010.
  1. grodenglaive
    grodenglaive New Member
    Apr 3, 2010
    313
    68
    Ottawa, Ontario
    for me it would run rough when I first started it in the morning, sometimes stall. It would run fine after warmed up. The dealer wouldn't replace it right away, made me wait until I had a new tank of gas (in case it was just bad gas). Then they said yeah, OK it's the hpfp.
  2. Metalman
    Just some additional information on this subject....
    N54 fuel pump failures
    In both the US and Canadian markets, the N54 engine has been plagued by a very large number of High Pressure Fuel Pump (HPFP) failures, leading to many BMW NA vehicle Lemon Law "buy backs" and reduced customer goodwill. On some engines the HPFP has failed more than four times within the first few years of service.
    BMW has instituted a 10-year, 120,000-mile (190,000 km) warranty on the part, but only for 2007, 2008 and 2009 model year vehicles with the N54 engine. Other model years, to include 2009 models, continue to report HPFP failures. As of late 2009, the low pressure fuel sensor has become suspected of causing some premature failures of the HPFP by engine tuners such as AMS and CP-E. BMW has engineered a newer HPFP model which has not resolved the issue. The new HPFP part number is: 13-51-7-594-943 and it replaces 13-51-7-592-881. BMW's failure to solve the HPFP problem has led to serious safety concerns over dangerous sudden losses of power at highway speeds. Reports of drivers being stranded are not uncommon and some have accused BMW of actively concealing the problem rather than addressing it. On October 26, 2010, BMW announced a recall of vehicles with the pump in question from manufacturing years 2007–2010.
    The current recall along with the replacement of the HPFP includes a recalibration in the ECU to prime the HPFP with the LPFP prior to the HPFP starting. The current part number for the HPFP for the recall is the same as that found in the BMW 1M.
  3. jiminni
    jiminni Well-Known Member
    262
    Ca.
    Think it's time for Mini to just extend the warranty on the whole engine :arf: But remember......it's the "engine of the year"...........
  4. Metalman
    From their eyes....
    If they resist individually... They probably come out ahead from a cost standpoint...
    Once the "Class Action" guys win... BMW / MINI is forced (legally) into a rather large cost to resolve the issue...
    Which probably explains their tact in dealing with defects... To hell with customer loyalty, what's the lowest cost option...
  5. Bill9912
    Bill9912 New Member
    Jun 2, 2017
    Does warranty apply on HPFP
    Hi Rixter,
    Just confirmed my HPFP is done. Do we know for sure the extended warranty is good in Canada? I hope so because this part is expensive.
  6. Rixter
    Rixter Well-Known Member
    Jun 14, 2009
    1,230
    79
    Technology Architect
    North of the 49th
    I just the email that I referenced on page 1 of this thread. Start by contacting BMW/MINI Canada and see what they say
  7. Rainman768
    Rainman768 Active Member
    May 3, 2012
    167
    81
    They did extend the warranty to later models. I had received a letter indicating my clubby was covered and how to submit a claim for compensation. Mine had failed last year at 119K. I filed a claim less than a month ago and received the check this week.
    The replacement was done by an indy mechanic and not the dealership if anyone was wondering if that mattered.
  8. lesterjohnca
    lesterjohnca New Member
    Jun 27, 2019
    Has anyone heard back from Mini Canada on the extended warranty?
    Got the below response.
    Dear Lester:
    Thank you for contacting MINI Canada. We appreciate the opportunity to assist you.
    Please be advised that extended parts warranties, much like recalls, are specific to the VIN of a vehicle based on factors like production dates, part affected, etc. Therefore, not every vehicle of the same year and model will be subject to the same extended warranties. Our records indicate that your 2010 MINI Cooper S bearing the VIN WMWM does not have an extended warranty for the High Pressure Fuel Pump at this time. We apologize for any disappointment this may cause.
    If you have any further comments, please contact the Customer Interaction Centre at 1-866-DRV-MINI. Again, thank you for contacting MINI.
    Sincerely,
    Ibrahima Ly
    MINI Canada
