2nd Gen JCW R56 JCW - Build Thread - New Set Of Pipes
Discussion in '2nd Generation: 2007+ R55 through R61' started by Metalman, Jan 19, 2011.
  1. Metalman
    I had to look closely to what you said, I definitely don't want it to look "RICER". I see too many Honda's running around town with those fart cannons drooping off the back of their bumper. Sticking with the MINI looking tips but just bigger to fill out the opening.
  2. DneprDave
    Ricer? You mean like this?:lol:
    Dave
  3. Justa Jim
    That just might prevent any tailgating. :D
  4. david in germany
    david in germany New Member
    Dec 15, 2010
    250
    If you want to reduce the tailgaiters drop the pipe size to .50cal :eek6:
  5. BThayer23
    Go big or go home. Double 4" slash-cut tips!
  6. Rixter
    Rixter Well-Known Member
    Jun 14, 2009
    1,230
    79
    Technology Architect
    North of the 49th
    #26 Rixter, Jan 20, 2011
  7. david in germany
    Dec 15, 2010
    250
    The more I see the stock JCW exhaust the more I like it.
  8. iwashmycar
    iwashmycar Active Member
    Jun 1, 2009
    881
    87
    architecture
    the paper mock up looks great. I also like the baffle flush with the center tube... both sticking out seems odd... no need to showcase the little ones
  9. Metalman
    Good point Adam....
    The neat thing about the muffler design that I'm going to build will have two removable / rebuild-able / tunable cores. So the shell (4" tubing) would remain in place and the baffle cores would be the removable parts. These cores should take no more than a few minutes to slide out of the muffles tubes without needing to get under the vehicle. I could even put separate designs on each opposite baffle core end. They could both be flipped, and have the small extensions visible or flip them both and have the flush surfaces visible.
    Chuck
  10. david in germany
    Dec 15, 2010
    250
    Sounds like the old Supertrapp design.
  11. k-huevo
    k-huevo Club Coordinator
    159
    Pipe Creek, Texas
  12. Metalman
    David...
    I'm thinking the Supertrap muffler used a series of stacked discs packs. Mine would operate more like a silencer for a firearm with a straight through exhaust.
    Chuck
  13. Metalman
  14. david in germany
    Dec 15, 2010
    250
    I was thinking about the rebuild able core not the diffuser disks. :) The original Suppertrapp had fiberglass stuffing that was replaceable but steel wool worked well also.
  15. Metalman
    #35 Metalman, Jan 20, 2011
    My center tube will also be 2-1/2" just like the tubing used on the exhaust pipe, except it will be perforated, 1/8" holes on 3/16" staggered centers (40% open) .060" wall T304 stainless steel. The chambers would be created with 3-13/16" OD discs welded to the perforated tube creating multiple chambers the length of the muffler. These chambers could be filled with high temperature insulation or scrubble. Or, the inserts could be completely removed for special track days.
  16. AXO
    AXO New Member
    Nov 25, 2010
    91
    Wellington, Florida
    #36 AXO, Jan 20, 2011
    Let me know if you need anyone to try them out when your finished. :D
  17. david in germany
    Dec 15, 2010
    250
    forget about it, he will have me test it on the Autobahn!!!:D
  18. Metalman
    Hah.....
    Yeah guys, this is all just a little experiment. If it turns out being a dud, well then all the bits and pieces get chopped up and get recycled into something like a bed pan or fence post. The scrap dealer will be happy and I'll end up with a few coins in my pocket.
  19. david in germany
    Dec 15, 2010
    250
    Evil man..:cryin:
  20. Justa Jim
    You really know how to tease your fellow JCW buddies, MM. :lol:
