2nd Gen JCW R56 JCW - Build Thread - New Set Of Pipes
Discussion in '2nd Generation: 2007+ R55 through R61' started by Metalman, Jan 19, 2011.
  1. Metalman
    Recently introduced.... Damn...
    If I end up adding a valve it will be just ahead of the rear mufflers. I want to be able to replace the packing. And it would be much easier if the valve wasn't inside my baffles.
    Sent from Arrakis, while harvesting spice, using Tapatalk when no one was looking.
  2. Redbeard
    1,636
    398
    Glorified spreadsheet jockey.
    I'm gonna PM you a thought I had later today because I need to make some "drawings". You might find it a useful idea to try.
    BTW, the Tapatalk sig had me laughing. Nice. Hopefully you harvest for House Atredies. ;)
  3. Metalman
    Been busy at work, but found a little time this past Saturday and knocked out my "Y" transition. This will be where the main trunk branches off into the two rear muffler / tips.
    It's moving slowly....
  4. CHKMINI
    great looking work, Chuck. Did you get the gauge/light issue resolved from yesterday?
  5. Metalman
    Que?:confused5:
    Got an appointment for 4/2. I think it's a bad cell.
  6. Bigprfed22
    Bigprfed22 New Member
    Dec 1, 2010
    95
    VA
    Looks great!
  7. Bigprfed22
    Dec 1, 2010
    95
    VA
    [ame=http://vimeo.com/22124043]Untitled on Vimeo[/ame] did a little work on mine:arf:
  8. Bigprfed22
    Dec 1, 2010
    95
    VA
    :confused5:no updates?
  9. Metalman
    Sorry, no.....
    I've been focused elsewhere. Just too many paying projects at work.
    Re-modeling of one of my rental units is about 99% done. I hope to get back on my personal projects soon, like maybe this coming weekend.
    In the mean time feel free to tell us about your pipes.....:D I was kind of curious how you made your's sound like a 747 doing a fly by......:Thumbsup:
  10. Bigprfed22
    Dec 1, 2010
    95
    VA
    [ame=http://vimeo.com/22123103]Untitled on Vimeo[/ame] heres another
    I took the resonater out of my invidia exhaust... not much more drone than usual which was almost none at all other than low gear high load. Sounds great :incazzato:just wish i could ride behind the car so i could enjoy it!
  11. Metalman
    Well.... It's been a while since I've had time to work on my exhaust.
    Found a little time today. This will become the rear muffler section. The "Y" transition will lead into two mufflers that will contain baffles and have a side benefit of being easily re-buildable without the need to remove the muffler from the MINI.
    Here are some pic's.....
    ImageUploadedByTapatalk1305751235.359136.jpg ImageUploadedByTapatalk1305751279.990456.jpg
  12. iwashmycar
    iwashmycar Active Member
    Jun 1, 2009
    881
    87
    architecture
  13. Metalman
    Well, I was able to spend a few hours down at the shop working on a couple of projects.
    I repaired a MOM member's JCW strut bar.
    Then I did a little work on my rear exhaust muffler. The housing is complete, however I still need to make the hanger bracket that will attach to the stock rubber isolation supports. I cut the two perforated tubes that will create the separation space for the ceramic insulation. The two discs will be a part of the rear hats that will cap off the rear of the muffler (I will punch a hole in each disc so the exhaust gasses can exit both cylinders)... That's it for today.
  14. Justa Jim
    Looking GOOD, MM. :Thumbsup:
  15. david in germany
    david in germany New Member
    Dec 15, 2010
    250
    Do you think you will ever finish this thing? ;)
  16. Metalman
    I've got sooooo many half started, half finished MINI projects going (that's the same thing, isn't it????)...... I guess I hope so. I've been finding more time to be down at the shop on the weekends with my wife being away at horse shows. The exhaust requires a lot of "under car" measuring of the existing exhaust. Without a lift, I've been dragging my feet a little on that part of the project. This weekend I'm going to see if I can use my forklift to raise the MINI from the side, since I have 8 foot forks. Will see where my jack pads line up with the forks.....:arf:
  17. Crashton
    :useless: We want to see that! :D
  18. david in germany
    Dec 15, 2010
    250
    Sounds like the next project, fork lift fork adapter to line up with mini jack pads.. ;)
  19. Metalman
    Already thought about that angle. I probably wont go any farther than just thinking about that idea. A ruptured hydraulic line would probably let the MINI down faster than I could react. MOM's would then start calling me "Shorty".....:D
  20. ScottinBend
    .....nah, just call you Squishy.
    [ame]http://www.youtube.com/watch?v=dpgNUS3prsw[/ame]
