Suspension Brakes 1st Gen R56 JCW front calipers top and bottom levers pushing out?
Discussion in 'Tuning and Performance' started by minsane, Feb 27, 2011.
  1. minsane
    minsane New Member
    Dec 13, 2010
    #1 minsane, Feb 27, 2011
    Hi guys:
    I recently had my R56 JCW brakes installed on my R53. After I worked out the bad bled problem that I had I went ahead and bedded in the pads and rotors. Now I think that I have another problem. The four sets of levers that are on the top and bottom of the front calipers are coming out. They appear as though they are about 1/4 of the way out. I tried pushing them back in by hand but they are stuck. They will not move. Is this normal? This has happened to the right and left sides. Should I be worried?
    Thanks again for your help.
    :confused5:
  2. goaljnky
    3,105
    394
    Can you post a pic?
  3. Metalman
    Hey.... Minsane
    Here's a quick pic of what my clips look like on my R56.
    Hope this helps?:D
  4. k-huevo
    k-huevo Club Coordinator
    159
    Pipe Creek, Texas
    Those are only there for pad removal convenience, something to grasp with the fingers, don't try to force them on/off or in/out, because the tabs will break from the pad's backing plate.
  5. minsane
    minsane New Member
    Dec 13, 2010
    Thank you very much Metalman for your pic. It's a relief to know that my clips are in the right position. I have had an adventure with these brakes on my R53. Getting the brakes was crazy, setting the banjos bolts was crazy, install took a long time, possible clearance issues (no problem for Kosei wheels), and my lines were bled incorrectly.
    After all of that I became a bit paranoid. These brakes a pretty nice on an R53.
    :arf:
