Suspension Brakes 1st Gen Rear Lower Control Arm Options
Discussion in 'Tuning and Performance' started by mini_racer, Nov 10, 2010.
  1. Way Motor Works
    Way Motor Works New Member
    206
    MINI Tuner
    Atlanta
    Hsport actually makes the ones for Promini. I can't recommend the Hsport control arms enough, I have customers that have had them on their cars since 2003 and not worn them out and AutoX bi weekly.
  2. CHKMINI
    Way, why?
  3. Way Motor Works
    206
    MINI Tuner
    Atlanta
    Why what?????????
  4. CHKMINI
    Why can't you recommend H-Sports? I'm looking for your input.
  5. Way Motor Works
    206
    MINI Tuner
    Atlanta
    It says I can't recommend them enough. They are the best, can't beat them.:Thumbsup:
  6. CHKMINI
    Way, my bad. When you're old like me sometimes reading on your droid is a bit difficult. And if you think that's bad....you ought to see me drive!
    Mark you need droid with a 30" screen. :D
  8. mini_racer
    mini_racer Well-Known Member
    Engr Manager
    So, why do you like/recommend them so much more than the other brands you carry?
  9. Way Motor Works
    206
    MINI Tuner
    Atlanta
    I've never had an Hsport fail, the TSW ones are good too, but as for other brands I've seen them all fail, and as early as only being on a car for a week before the joints became loose.
  10. mini_racer
    Engr Manager
    Well that is a strong reliability endorsement, thanks for the info.
  11. MiniHockey
    MiniHockey New Member
    Oct 20, 2010
    109
    I raced dirt track for years and we used these rods. I dont know why they wouldnt work for these cars and they are a hell of a lot cheaper and quality is #1.
    AFCO: "SWAGED STEEL TUBE - 16"" (THREADED 1/2"")"
    These are also used on indy cars and Nascar. Would just need to know the length before you order.
  12. INU
    INU New Member
    Dec 2, 2009
    Check out Ireland Engeering's Ver.2 rear arms.
    I have had them on my 05'S for 40k and have had no noise , no braking nuts
    loose. Been on track a few times and see's 15 miles of canyon driving every day.
    H-Sport's are good but have been known to loose-up under hard driving conditions.
    Beware spherical rod ends! Smoothest operation , but short life span and
    lots of noise for street use.
    Hope this helps, Scott B.
  13. mini_racer
    Engr Manager
    #33 mini_racer, Nov 12, 2010
    Thanks for the input INU and Welcome to MA!
    The IE links look like a nice beefy design, but the endlinks are blue. :(
