Interior 2nd Gen Rear Seat Delete
Discussion in 'Tuning and Performance' started by Justa Jim, Feb 28, 2011.
  1. Justa Jim
    Yepper, according to the calculations I made with my trusty slide rule, I should be able to get about 174 dozen back there. That should be enough for half the MOM members. :Thumbsup:
    I'll bet MM still has a slide rule, but there are some reading this and scratching their heads. :lol:
  2. Metalman
    Jim,
    Slide rule.... Hah, I don't use it.
    I just take the answer and work backwards. Works for me..... :D
  3. Justa Jim
    Now you tell me the secret. All I had to do was take the correct curve for the RSD and work back from there. Why didn't I think of that? :eek:ut:
  4. Justa Jim
    I want to secure the front, center of the RSD floor board, but don't know what is under the hump right in front of the rear passenger foot wells. Anyone have a diagram for a 2nd Gen MC?
  5. david in germany
    david in germany New Member
    Dec 15, 2010
    250
    Baker or standard dozen?:lol:
  6. Justa Jim
    Keith got it for me. The Gas Tank is under there. :eek6:
    You'll want to use a self sealing self tapping screw. :D
  8. Justa Jim
    I'll re-think it instead. :Thumbsup:
  9. Justa Jim
    Installed Hush Mat dampening material. Better, but not exactly right yet. Need a sound barrier too, so back to the Speed Shop.
  10. CHKMINI
    The donut rack is the last item to install :idea:
  11. Justa Jim
    Right, I'll ask if they have one of those too. What was I thinking? :eek:ut:
  12. Justa Jim
    Final changes to the RSD are again noted in post #70. This is much, much better. Not cheap, but it actually works.
    BTW: Doughnut rack had to be special ordered. Local Speed Shop said there is not much call for them, but we found one that is NASCAR approved. :Thumbsup:
    Jim.
  13. Justa Jim
    Final post in this saga:
    Doing all I did to the under section of the seat made a huge difference, but there was still some, not a lot, but some remaining noise.
    After adding the sound barrier, under the tool box, over the tool box and sliding a small piece under the small area of floor mat on each side of the panel covering the tool box, all noise is gone. There was more sound coming from the rear wheels and the exhaust than I had thought. The car is quieter then it has ever been, even with the seat in.
    Even if you have not done an RSD, I highly recommend you address the small storage area of the boot. It can be done cheaply and will be well worth it.
  14. CHKMINI
    Jim, so .......no donut racks?
  15. Justa Jim
    Check out post #92. It is on special order. NASCAR approved and will keep doughnuts secure for 500 laps. :Thumbsup:
  16. scanner
    scanner New Member
    Oct 9, 2010
    I'm thinking of doing mine...05 MCSa...I never use the back seat anymore
  17. Justa Jim
    I really like it, but if you don't do the sound dampening it is very loud.
  18. Dwight
    Dwight Racing with the Gods
    329
    12
    RETIRED!!
    San Marcos, Calif.
    Pulled my rear seat cause it's been used maybe 5 times in +3yrs and I tend to haul some pretty bizarre stuff occasionally. Considered that RSD kit, but turned it down. Too expensive and a pretty poor design IMHO. If you put anything on it, there's no easy way to secure it and if I remember right a MINI does tend to corner/brake rather briskly! Also, it actually deletes potential cargo capacity by being mounted so high. Went to an old fashioned auto carpet shop and the guy hand cut a piece of self forming carpet, edged it and slotted it for easy access to the seat and belt anchor points. The stuff is also a sound deadener. Had to change the F/R sound balance a little, but that's it. The cost was horrific: $50! And I saved 35-40lbs, too. :D
  19. Justa Jim
    Nice job. I thought about leaving the dip back there, but flat worked better for me. :Thumbsup:
  20. ScottinBend
    Now I like that mod.........will have to really think about that one.
