Engine Drivetrain 1st Gen Cooper S Reason for axle popping out???
Discussion in 'Tuning and Performance' started by Octaneguy, Mar 19, 2010.
  1. Octaneguy
    Octaneguy New Member
    Apr 24, 2009
    579
    31
    Dream job
    Anaheim, CA
    Thanks!! Your advice has been awesome! Thanks so much!
  2. Rooster
    Rooster New Member
    May 22, 2009
    Systems Engineer
    West Hollywood, CA
    This makes me wonder if my own axel popping noise isn't from loose/missing bolts as well.
    Can anyone tell me if the transmission bolts get loosened when you raise the engine up to install a pulley?
  3. Chase
    Chase New Member
    this is all great information. i have had this same issue, and have only had it pop out twice. then just put in a new axle. havent had the issue in a few thousand miles.
  4. Some Guy
    Some Guy New Member
    Jan 2, 2010
    Chase, were you also running an OBX diff?
  5. Octaneguy
    Apr 24, 2009
    579
    31
    Dream job
    Anaheim, CA
    I believe my axle popping problems are over. The car is driving like it used to before all of this happened. The diff was bad that I got from Danny, but now my car is overheating..seems to be leaking coolant from somewhere. Topping the coolant off daily oh and my car no longer opens from the inside..gotta pull the door panel and see what happened.
  6. BlimeyCabrio
    Dude.... I feel your pain.
  7. Camaro
    Camaro New Member
    Industrial designer
    Check your thermostat gasket. I had the same issue and it turned out to be a deteriorated gasket.
  8. Octaneguy
    Apr 24, 2009
    579
    31
    Dream job
    Anaheim, CA
    Oh my RMW header is rattling again even though it was rebuilt by RMW's Mike who fabricated them....just never ends.
    Yeah Nathan told me the same thing. One thing though..I'm suspecting it's the coolant reservoir, but I don't know enough if these clues are a sure sign it's leaking or just part of the problem?
    I let the car cool, cleaned the tank off, refilled it with MINI coolant, I cleaned the areas around the tank so no coolant was around. I drove for about 10 minutes..temps stayed around 195 as long as I was moving, sometimes going as low as 185, but as soon as I stopped would climb to 225 when the fan would come on. I pulled over and could smell coolant and could hear sizzling from what appeared to be coolant dropping on the header.
    The tank had coolant on the outside of it, as well as on the nearby heatshields. A huge pool of coolant flowed under the car. I could detect steam coming from the coolant cap and could hear hissing from it. I took some iPhone video and will post it later.
    Does that sound like anything other than a leaking coolant tank?
  9. Octaneguy
    Apr 24, 2009
    579
    31
    Dream job
    Anaheim, CA
    Here's what's going on
    [ame=http://www.youtube.com/watch?v=x8nzPWK92Lg]YouTube - Leaky Coolant Reservoir on 2005 MINI Ccoper S[/ame]
  10. Dr Obnxs
    Dr Obnxs New Member
    Jun 11, 2009
    1,158
    IT could be the tank
    the cap, or just overflowing because you're getting vaporization somewhere in the head. I got a tank from Classic Auto Campus with the 20% NAM discount. It's an easy install. Others like the Al cans but they also put out more heat than the plastic does, and cost almost 10x as much!
    Start with the cheap parts....
    Matt
  11. Octaneguy
    Apr 24, 2009
    579
    31
    Dream job
    Anaheim, CA
    Thanks, yeah I've got a new tank on order which includes the cap. I saw those metal tanks but the cap alone costs $30! My local dealership wants twice of retail which was nuts but typical out here. Thanks for the help Matt.
    I've had this happen as well, however not to the point of overheating and I have a metal tank that uses the OEM Cap.
    The caps go bad. A MINI tech told me there are two types out in the wild. The only difference being the gasket.
    I think he said:
    Blue Gasket = Good
    Black Gasket = Replace
    No, the gasket does not change color, supposedly the blue gasket is made of better stuff.
    I try and remember to verify at our MetroplexMINI.org DIY Day at MINI of Dallas.
    BTW, the OEM cap is really inexpensive as MINI parts go. I think I paid 6-7 bucks. Good item to toss in glovebox.
  13. Octaneguy
    Apr 24, 2009
    579
    31
    Dream job
    Anaheim, CA
    I'm pretty sure I have the blue gasket. My build date is 4/05 so it's exactly 5 years old now with 110,000 miles. I hope it's just the cap! When I get the new tank, I'll put see if the cap solves the problem before putting in the new tank.
    I love you guys! lol....ok..I've been having some really difficult months with my MINI and was pretty much ready to dump it...but starting to feel the love again.
    Richard
  14. Nathan
    I am so glad I didn't add that group hug smiley :D
  15. Rooster
    Rooster New Member
    May 22, 2009
    Systems Engineer
    West Hollywood, CA
    Warm and cozy or not... time to get rid of that thing.
