Reconditioned r53 Valve Train 8 r53 intake Valves 8 r53 exhaust valves 16 new Valve guide seals 16 r53 Valve springs and retainers *Valves and Valve Springs are cleaned and tested. * All valves are Mic'c for correct OEM dimensions. *Valves springs are all tested for correct and balanced Pressures. *Valves are faced, and the "Flow cut" is added. *New Valve seals and OEM retainers are included. Perfect for up-grading your r50 to the stronger and more resilient r53 Valves. Cost: $226.00 USD ( 145.00 GBP) FREE Shipping. ( US and UK) Dont forget we also have all the gaskets needed for that HEAD change. Intake gasket - Exhaust gasket- Valve cover gasket- Head Gasket : $186.00 ( 119.00 GBP) Or the complete gasket set AND ARP Head studs all for: $350.00 (225.00 GBP) Thanks Thumper
repair shop in Central Fl......." Mike, I have a r50 in the shop that has a valve that looks like a blowtorch cut right thru it!! Have you heard of this happening on the r50 MINI's??" The answer is YES!! This r50 has 80K on it. And the valve is burnt. Was it the fault of the valve?? NOPE!! Running lean ( this IS a smog engine) and high temp, over a period of time, will cause the valves to burn. Upgrading to a more resilient Valve material would be a good idea now.. as your shop is going to replace it with the r50 like part. This KIT is right in there for you. $226.00 Check the cost of all the top end gaskets ( $186.00 ) Or all the gaskets AND ARP studs: ( $350.00) Thanks Thumper
