Removing air bubble from sport stripe?
Discussion in 'Detailing' started by Rixter, Oct 18, 2009.
  1. Rixter
    Rixter Well-Known Member
    Jun 14, 2009
    1,230
    79
    Technology Architect
    North of the 49th
    I had Spike's stripes changed this past week. Had the stock white removed and change for the MINI Sport Stripe. Looks great.
    Today while washing I noticed an air bubble about 1/4" in size near the edge of the graphic on the boot of the MINI. Should I...
    1. Poke it with a pin
    2. Use a credit card to try to smooth out (I'm worried about stretching the vinyl and creating a permanent ripple)
    3. Wait a couple of weeks and it will work it's way out
    4. Take it back to the dealer and have them fix it
    5. Ignore it
    Comments?
  2. zied
    zied Club Coordinator
    May 27, 2009
    38
    Building Designer, Energy Analyst
    Healdsburg, CA
    wait a couple of weeks... if its still there return it to whomever did the install
  3. TWISTER
    TWISTER Active Member
    52
    Web Developer/Designer
    Piedmont Triad, NC
    It might still have water under it. It will evaporate if you live in a hot climate. Pop it with a pin and leave it alone
  4. lotsie
    400
    stagehand/part time detailer
    Right here
    I tend to agree with the leave it alone theory, for a week or so. Try and leave your MINI in the sun. If it is still there in a week or so, then poke it with a pin. If you don't want to wait, take it back to the installer.
    Mark
  5. BlimeyCabrio
    ... who will then poke it with a pin for you. :yesnod:
  6. Rixter
    Jun 14, 2009
    1,230
    79
    North of the 49th
    I've got Spike sunning himself, rear-side facing south. The temp will be about 60 degrees today, last decently warm day for a while. I'll see if that helps. I've heard mixed reviews about poking with a pin.
  7. orangecrush
    orangecrush New Member
    May 13, 2009
    137
    Leave it alone for now. Typically if the bubble is big, it'll shrink itself to the point you can use your thumb on it. At that point, there will probably still be a TINY little bubble.
    THEN, you can prick it with a pin.
    My suggestion is to work it with your thumb rather than a credit card or likewise. The reason is, if the bubble is too big, it'll stretch the vinyl and fold over on top of itself.
    My .02 worth.
    Mark
  8. Rixter
    Jun 14, 2009
    1,230
    79
    North of the 49th
    I parked it out in what will be the last day of sun and warmth til next March! So far no difference. We're getting down to zero temps at night and unlikely going to hit another day of 60 degrees.
    What about a hair dryer after a couple of weeks?
  9. lotsie
    400
    Right here
    I would stay away from a hairdryer, back into that whole stretch issue. Let it sit and leave it alone for at least while it sits in the sun.
    Mark
  10. lotsie
    400
    Right here
    You may actually be fortunate that it is getting cold tonight, it may shrink down the air bubble.
    I would do nothing, besides sunning, and waiting a few days. Then take it back to the installer. Put the fix on their coin, not something you did.
    Mark
  11. Rixter
    Jun 14, 2009
    1,230
    79
    North of the 49th
  12. TGS91
    TGS91 New Member
    May 8, 2009
    1,593
    17
    Sales Dude
    St. Louis, MO
    not sure if still a issue Rixter. Had a new stripe put on at MITM and a air bubble showed up right after install. Mike at Aesthetic Creations whipped out a small utility knife, put a small incision in it, rolled a straight edge over it and I haven't seen a sign of it since.
    Other than the fact it looks like very wide electrical tape now it's fine, no bubbles
  13. Rixter
    Jun 14, 2009
    1,230
    79
    North of the 49th
    Well its been 2 weeks now, unfortunately the temp has never gotten above 55 degrees again (since its now the fall) so evaporation is not about to happen. I really dont want to have it cut or poked. I think I'll leave it and see what happens in a month
  14. TWISTER
    52
    Piedmont Triad, NC
    use an alternate heat source other than the sun, a hair dryer. Works just as well. Popping it is almost always necessary. Take it from someone who knows. I have side decals to do tomorrow and as cool as it is, I'll be popping a few tomorrow
  15. Rixter
    Jun 14, 2009
    1,230
    79
    North of the 49th
    So if the hair dryer is a bust, and it does need to be popped will it eventually get dirt (or water) under the pin-hole?
  16. TWISTER
    52
    Piedmont Triad, NC
    no, unless the hole gets bigger, which it shouldn't, The vinyl is fully covered in glue on the reverse side. Nothing has ever gotten in mine or made it larger
  17. Rixter
    Jun 14, 2009
    1,230
    79
    North of the 49th
    Awesome, fanks!
  18. TGS91
    TGS91 New Member
    May 8, 2009
    1,593
    17
    Sales Dude
    St. Louis, MO
    Ditto on Twister's note
    No problems and it's been like 3 mo's.
    I don't think there is anything really to evaporate. These are Vinyl with a adhesive backing. I think the longer you wait the less chance of success
