Brakes Wheels 1st Gen Tires Repainting wheels - Vote for a color
Discussion in '1st Generation: 2002–06 R50, R53 & 2004–08 R52' started by Mike, Jun 21, 2011.
What color for the wheels? Vote for the one(s) you like.
  1. Silver
    8 vote(s)
    25.8%
  2. Black
    13 vote(s)
    41.9%
  3. White
    12 vote(s)
    38.7%
Multiple votes are allowed.
  1. Mike
    Mike New Member
    Step one is the strip off the old paint and prepare the surface to accept the powder coating. This means bead blasting or grit blasting until the wheel has a matte finish. Step two is to clean up the wheel with some alcohol and compressed air to remove the dust. Step three is to set the wheel up in the booth and apply an electric charge to attract the powder coating material, in this case polyester powder. The last step is to put the wheel in the oven and bake the paint for about 15 minutes at 300 F. The result is a tough, resilient finish that is very weather-resistant.
  2. KittyMini
    KittyMini Club Coordinator
    1,183
    Wow, and now I know :Thumbsup:
  3. Rixter
    Rixter Well-Known Member
    Jun 14, 2009
    1,230
    79
    Technology Architect
    North of the 49th
    Mike, if this was a DIY project using rattle-can instead of powder coating, can the wheels be sanded with a fine grit and then primed and spray painted?
    Great instructions BTW. Thanks
    Is that finish then heat resistant enough to use on the track with high brake temps? I ask because I've read of high-heat powder coating paints. I imagine those are for much higher temps but it still leaves me wondering about poly powder cooked to 300 F.
  5. Mini-Rolls
    Mini-Rolls New Member
    Jun 6, 2009
    13
    OWNER
    Olympia, WA
    I painted my wheels a few weeks ago. The inside of the wheel is flat black with a flat clear coat, the spokes are black with blue pearl and a few coats of high gloss clear.
  6. Mike
    Mike New Member
    Absolutely, I've done this on wheels in the past. Duplicolor wheel paints are particularly good for refinishing wheels.
    I've had powder-coated wheels at the track and have yet to cook the paint there. The powder used was just plain-jane polyester powder. They do have some higher temperature powders (epoxy, mixed-blend) and of course the really high-temp ceramic stuff, but as you go up in temperature tolerance, weatherability goes way down.
    Can't see your pics on my computers, would like to see them though. The "click to see full-sized pic" link takes me to a forum that then tells me I'm not logged in and am therefore forbidden to access the page.
  7. cct1
    As much as you hit the track, White is out.
    It's a personal preference thing, but silver looks very classy on Blue; black really doesn't look so hot with blue and a white roof, but that's just me, plenty of people have done it so there is a fan club of it.
    Thing is, if you're doing these custom, you could maybe do the lip in a different color--if you did the lip in the same blue as your car, and the rest of the wheel black, now that might look pretty slick, and tie the black in better. Don't know if you can do that with powder coating though.
    I'd vote for plaid, but it wasn't an option.
  8. Justa Jim
    Just my luck. My wheels won't fit in my over. :nonod:
  9. Rixter
    Jun 14, 2009
    1,230
    79
    North of the 49th
    Jim, you need to tell your wife that you're going to buy her a new super-delux-jumbo-stainless oven that also happens to accomodate up to 20" rims. :lol:
  10. Justa Jim
    Since I do the cooking, maybe this is my chance to buy the Vulcan Range I always wanted. :lol:
  11. Metalman
    Can you do the Vulcan Mind Meld as well?.....:D
  12. Ofioliti
    Ofioliti New Member
    35
    Professor
    ... always curious
    White roof must have white wheels! :biggrin5:
  13. Rixter
    Jun 14, 2009
    1,230
    79
    North of the 49th
    Probably not, but I'll bet he makes a killer tuna melt ;)
  14. Johngo
    Johngo New Member
    1,671
    200
    Art Director
    Sugar Hill, GA
    Vulcan Killer Tuna Meld? :confused:
    :D
  15. BlimeyCabrio
    +1 for Anthracite / Gun Metal (non-brownish) - dark silver color
    If I ever need to refinish my PF01's, that's what they will become.
    But, of the options given to begin with... silver.
  16. Mike
    Mike New Member
