1st Gen R53 Cooper S Replacement radiator fan sources
Discussion in '1st Generation: 2002–06 R50, R53 & 2004–08 R52' started by vargasgal, Oct 13, 2010.
  1. Dave.0
    #21 Dave.0, Aug 27, 2018
    https://www.northamericanmotoring.com/forums/stock-problems-issues/174040-low-speed-fan-resistor-we-need-solution-38.html
    Don’t buy that Doorman crap. Here is the solution I have used after mine failed in 2007 and have not had any issues since. See post 113 in the tread below.
    Also I am still using my original fan assembly from 2005.
    Mouser Part #: 284-HS100-0.47
    Manufacturer Part #: HS100 0R47 5%
    Below I have died some pictures of how the Mouser part is mounted and wired. Please review the NAM thread for all the specifics.
    https://www.northamericanmotoring.com/forums/stock-problems-issues/174040-low-speed-fan-resistor-we-need-solution-3.html
  2. Minidave
    Your MINI Dealer now has a repair kit for the fan too, you might check with them....my understanding is it's a plug and play solution.
  3. beken
    beken Well-Known Member
    Jan 13, 2010
    1,405
    1,829
    Delta, BC
    I first installed an aftermarket one and , though it worked, it was noisey and vibrated a lot. Got a stock one from MINI and noticed the fan blades were individually balanced with weights attached at various locations. I also kept my old one so I can fix the broken resistor coil myself and just swap the radiator the next time this happens .
  4. clifforddward
    clifforddward Active Member
    Dec 2, 2013
    104
    76
    Cary, North Carolina
    For what it's worth, I am confident most "fan failures" are actually just the fan relay which is mounted in the fan housing...ala the part just mentioned above from Detroit Tuned. You'll want to do some soldering when replacing the relay, and still need to pull everything apart to get at it...but once you to you'll see the resistor inside that I believe is what primarily fails...it is an extremely simple circuit that absolutely will fail over time...might as well consider it a maintenance replacement item.
    This was a common fail that was talked about here on the forum in the past, with DIY resistor replacements outlined...haven't seen much mention of it since the relay replacements became available.
    There is a test to determine if your loss of low speed fan is due to the relay...maybe a check of postings on the forum would find the old thread.
