Request your MINI factory repair manual infomation here
Discussion in 'MINI' started by oxybluecoop, Dec 14, 2009.
  1. oxybluecoop
    oxybluecoop New Member
    Jun 7, 2009
    29
    IT/Sales/SnowCat Operator
    Morgan,UT
    Bumping this thread to let folks know they can still make requests.
  2. Checkpoint
    Checkpoint New Member
    Aug 24, 2010
    Anything on carbon removal from DI systems (R56) and the mileage service interval for this? Or recommended additive usage for the control of Carbon buildup in the intake valve tracts?
  3. Justa Jim
  4. TGS91
    TGS91 New Member
    May 8, 2009
    1,593
    Sales Dude
    St. Louis, MO
  5. beken
    beken Well-Known Member
    Jan 13, 2010
    1,405
    1,829
    Delta, BC
    What's the torque setting for the bolts to the engine for the mounting bracket that connects the lower engine mount to the side of the engine for the R53 MCS?
  6. Shifter
    Shifter Member
    86
    24
    Southeast Michigan
    #26 Shifter, Sep 12, 2010
    R52 door panel & lower control arms
    I'm ready to replace my front OEM speakers with Polk 6501's, so I need to get the panels off. I'm also replacing my rear lower control arms with TSW's, and could use a picture or two if they're available. Thanks for the offer to help!
    Update20100927: Control Arms installed. Not that big a deal really. A little tricky getting a socket on the nuts of the upper bolts, but a swivel and a short 18mm socket will get it done. Still hoping to see something on removing the door panels.
  7. Wadodude
    Wadodude New Member
    Aug 31, 2010
    42
    Programmer
    The colony
    Replacing the stock Injectors
    Are there any write ups on removing the stock 330cc injectors for R53?
    I'm looking to do a tune up soon but I need to check my injectors to see if it is stock or not.. If I need it I will upgrade to jcw 380cc...
  8. iwashmycar
    iwashmycar Active Member
    Jun 1, 2009
    881
    87
    architecture
    I assume you are referring the the plug price and not the socket. Socket is $5 ($50 @ MiniMania LOL)
    They're something like 14 ea. for plugs. Look up these numbers @ parts.com
    http://www.realoem.com/bmw/showparts...& hg=11&fg=30
    Oil filter kit 11427557012
    http://www.realoem.com/bmw/showparts...& hg=11&fg=18
    Engine Belt (up to 1/2010) 11287566789
    http://www.realoem.com/bmw/showparts...& hg=13&fg=20
    Non-Turbo Air filter 13717561235
    http://www.realoem.com/bmw/showparts...=64&fg=10&hl=2
    Activated Carbon Cabin Filter 64319127516
    Fuel filter: 11252754870
    S air filter: 13717568728
    Belt: same as above
    Oil filter: same as above
    Plugs: 12120035531 (NGK ILZKBR7A-8G)
    Wipers: 61610028137 (front) 61622754285 (rear)
  9. Dr Obnxs
    Dr Obnxs New Member
    Jun 11, 2009
    1,158
    This is so easy....
    it's doesn't really require a write up.
    Take of IC (cover first, boot clamps pull away).
    Take off connectors from injectors.
    Release gas pressure by method of choice (rag around hose connector or Schreader valve).
    Remove fuel feed.
    Remove vac line from pressure regulator.
    Use compressed air to blow dirt off from base of injectors.
    REmove two bolts that hold the rail in place.
    Pull out fuel rail with injectors attached.
    It's a really fast job. It's good to have some o-rings around, as the ones at the tips of the injectors get cooked and can stick to the intake manifold and tear. If you're installing new they will be on the new ones. If you're having your injectors cleaned they will replace them anyway.
    Matt
  10. TGS91
    TGS91 New Member
    May 8, 2009
    1,593
    Sales Dude
    St. Louis, MO
    Thanks Adam
    I found the plugs on Amazon for that cost.
    I didn't pay the MINI mania price. I did pay about $30 and feel like a bit of a noob (which in a allot of instances I am) but it is magnetized and getting the plug out and in of the 6-8" vertical access tube to the plugs was a breeze. Not so sure it would have been so easy with a straight 12pt 14mm socket
  11. joey4420
    joey4420 New Member
    Jun 26, 2010
    Liberty Twp OH
    I am trying to install the one touch sunroof option on my Clubman... do you have the wire info for the sunroof and switches to make sure I have it right... having some issues.
  12. BThayer23
    Any chance you have access to Service Bulletins? I'm looking for SIB 12 02 05, which is hopefully related to a P0136 code. Thanks!
  13. jeffster06
    jeffster06 Active Member
    Apr 23, 2010
    420
    111
    Dallas, GA
    I'm dealing with an on going code it kinda points to the throttle position sensor do you have the schematic for the TPS for an 06 MCS?
  14. NAProf
    NAProf New Member
    Jun 1, 2009
    6
    College Professor
    Severna Park, MD
    Sunroof Adjustment Question
    I am getting a lot of wind noise with my sunroof closed on my R56 S. I checked the TIS specs and it says the leading edge of the glass should be at least 1 mm below the roof line. The trailing edge of the front glass is suppose to be 1 mm above the front edge of the rear glass, and the trailing edge of the rear glass should be at least 1 mm above the roofline. My trailing edge of the rear glass is about 10 mm below the roofline.
    I have seen some comments on various forums about 4 adjusting T25 screws, but I want to know where they are. Are they on the pivots that lift the sunroof? Any advice on doing the adjustment?
    Thanks in advance.
    Cheers,
    Greg
  15. Sour Krauts
    Sour Krauts New Member
    Dec 12, 2010
    I am looking for step by step instructions on resetting the service monitors (oil, brakes, etc.) on a 2011 hardtop. Have been searching the site (search function with obvious key words) but nothing clear as of yet. Can someone direct me to a thread that may contain this information our post the service manual section on these resets?
  16. Nathan
    This was written before 2011 so I'm not 100% sure it is valid but please take a look and let us know.
    Service Reset Procedure
  17. Sour Krauts
    Dec 12, 2010
    Nathan,
    Thank you for the quick reply. I will let you know what I find.
