Review: The Raceseng Slammer Shift Knob
Discussion in 'Feedback, Reviews & Comments' started by Zillon, Dec 8, 2014.
  1. Zillon
    Zillon Well-Known Member
    Jul 12, 2014
    702
    632
    Central NJ
    I may have to get a Topologi for the winter months. Or just a pair of gloves, I suppose.
    Just put a glove or sock on the shifter.
  3. Savvy
    That'd be my trick. Unless Jarrett @ Raceseng uses the same threaded mounting fixture to do all his gate engraving... you'd need to adjust the adapter each time to swap knobs. Unless, you get the slamologi knob without the visible engraving.
  4. cct1
    Nah, put an unlubricated condom on it. Ribbed. Nice insulation, good grip. It would be the ultimate conversation piece.
  5. TheModFather
    Only you CCT... Just dont turn it inside out... They only work one way. :p
  6. Zillon
    Jul 12, 2014
    702
    632
    Central NJ
    I had asked this question - you will need to adjust the knob each time.
    Or just get an unengraved one, but where's the fun in that?
  7. TheModFather
    Don't they screw onto the adapter for the shift lever? Would a jamb nut be a possibility?
  8. Savvy
    could be. But I think they use a goofy thread for the knob to screw onto. Plus, if you scroll up in the thread a bit... you'll see that for our applications, not that much of an option given the adapter vanishes inside the knob.
    See what I mean...
    [​IMG][​IMG]
  9. TheModFather
    How about a high tension spring stuffed in the receptacle on the bottom of the knob... Screw it down, the spring will compress and cause enough tension for the knob not to spin, just center the lettering and leave it?
  10. Savvy
    You'd be better off with a custom made washer... but it's not that hard to adjust the adapter. There really isn't room for a spring.
  11. TheModFather
    Ah yes pic's help! Yeah, I'm out of easy suggestions, and seeing it there really isn't any room.
    I would probably just keep it the way it is... One plus side of a metal knob in cold weather, lick your hand... You'll find out! :D
  12. packimocity
    packimocity New Member
    Oct 13, 2010
    147
    85
    Education
    NE PA
    If winter ever ends (more snow today) here in NE PA, I promise to install the ChiliRed slammer, a Christmas present, into my wife's R53...I wil post photos with a fresh interior detail
    pac
  13. narvarr
    narvarr Active Member
    Nov 8, 2014
    183
    116
    Maintenance Tech
    Rowlett, Tx (Dallas Metro)
    Great write up and after reading it, I decided I had to have one. I went with the heavier Ashiko knob. Great feel and wonderful craftsmanship.
  14. Zillon
    Jul 12, 2014
    702
    632
    Central NJ
    Great choice!
  15. ColinGreene
    ColinGreene Well-Known Member
    438
    293
    Orange county Ca
    Would go nicely with one of my short shifts.
  16. Zillon
    Jul 12, 2014
    702
    632
    Central NJ
    They pair fantastically with a short shifter. :Thumbsup:
  17. TheModFather
    Why cant they just make a large round ball with the right shift pattern engraved on the top? I love the look of the white ball in the Rat, but it is light weight plastic. :(
  18. Zillon
    Jul 12, 2014
    702
    632
    Central NJ
    FWIW, the slammer feels better than a pure ball shifter, at least to me.
    The elongated shape also helps hide the adapter hardware, too.
    Agreed, though - a ball shifter does look fantastic.
  19. packimocity
    Oct 13, 2010
    147
    85
    Education
    NE PA
    thanks M Savacool for getting this looking good for me!
    pac:wink:
  20. Savvy
    Anytime, Pac.
