Engine Drivetrain 1st Gen Cooper S RMW Custom Tune Party in Austin, TX, Oct 15/16
Discussion in 'Tuning and Performance' started by mini_racer, Aug 27, 2010.
  1. mini_racer
    mini_racer Well-Known Member
    Engr Manager
    #21 mini_racer, Sep 11, 2010
    OK, penciled in for the 4pm Saturday slot.
    OK, Saturday Standby/waiting list for you. The earlier you get to the shop the better your chances I will have of squeezing you in.
    Edit: Ok, you are penciled in for 5:30pm on Saturday.
    We can thank RonsMinnie for being flexible on his slot. :Thumbsup:
    OK, penciled you in for 1pm Friday.
  2. mini_racer
    Engr Manager
    I do need your deposits to Lock-in your slot. PM me.
  3. futuremini
    futuremini New Member
    Jun 11, 2010
    60
    Oklahoma
    If the Friday 2:30 slot is still open I would like to take it please. I will be coming from Oklahoma early Friday Morning.
    Thanks,
    Mike
  4. mini_racer
    Engr Manager
    Ok then, the final slot has been spoken for. Welcome to the fun!. You are penciled-in for the Friday 2:30pm slot. PM me to lock it in!
  5. futuremini
    Jun 11, 2010
    60
    Oklahoma
    Great! I look forward to meeting everyone!
  6. 90intherain
    90intherain New Member
    Sep 17, 2010
    San Antonio, TX
    Am I too late for a spot?????
  7. mini_racer
    Engr Manager
    You can at least get on the Standby list, and maybe a slot. PM me with your preferences on when you want a slot.
  8. Wadodude
    Wadodude New Member
    Aug 31, 2010
    42
    Programmer
    The colony
    Does anyone has 380cc injectors that they would like to sell to me?? I really want these injectors for used price so that I can do this tune this year.
  9. mini_racer
    Engr Manager
    If you want/need spark plugs:
    1st gen cars on the list: Let me know if you want Jan to bring the proper plugs for your car based on your mods. Cost is $40/set. We can change them before your tune, no problem.
    2nd Gen cars on the list: Follow the MINI recommendations.
  10. mini_racer
    Engr Manager
    #30 mini_racer, Sep 19, 2010
    For you 1st Gen people a critical maintenance item is the serpentine belt as it runs the SC. Regardless of the miles or years a simple test is to check the tensioner spring compression. A compressed spring indicates a tight (non-slipping) belt, and a spring that is more extended indicates an older/more stretched, and possibly slipping belt.
    Definitely if your belt is making any noise, or is frayed in any way, change it.
    Follow this to a great How-to on belt replacement.
    http://www.motoringalliance.com/library/1st-generation-mini-cooper-how-to-3/replacing-the-serpentine-belt-on-an-r53-mcs-3/
    I will have my tensioner tool on hand as well as a spare belt or 2, just in case.
    Here is a pic of the belt tensioner spring with a brand new 060535 belt and a 15% pulley, notice the entire hole is showing, this is good and indicates a nice tight belt. When the belt gets to the point that only half or less of that hole is showing then you may be getting some slipping. So, it is time for a new one.
    1st Gen cars (i.e. R53) tend to be a little hard on belts and require more frequent changes than average due to the extra stress from turning the SC.
    2nd Gen S cars will have a more typical experience with their serpentine belts given that they have a turbo.
  11. mini_racer
    Engr Manager
    OK, I will request that Jan bring in 3 sets of spark plugs as per the requests. Let me know ASAP if anyone else needs plugs.
    So far: mini_racer, Cheezeit, 90intherain
    Let me know ASAP so Jan can have them available at the tune.
  12. Wadodude
    Wadodude New Member
    Aug 31, 2010
    42
    Programmer
    The colony
    Yes I do need spark plugs as well... I had pm'd you about that. Thanks!:popcorn:
  13. mini_racer
    Engr Manager
    Ha Ha, I knew there was one more.....
    Ok, got it.
  14. Davidoyo
    Davidoyo New Member
    Sep 13, 2010
    Do you know if Jan sells RMW stickers? Because I have seen them on Minis, but never found out where to buy them.
  15. mini_racer
    Engr Manager
    No, sorry he does not sell RMW stickers. However, he does give them away. I am sure though if you insisted on paying he would take your $$. :D
    More seriously, I will make sure and remind him to bring us some stickers. He has several different styles colors and sizes.
  16. Davidoyo
    Davidoyo New Member
    Sep 13, 2010
    Sweet thanks:Thumbsup:
  17. Todd Wilson
    Todd Wilson New Member
    Jun 2, 2009
    14
    I going to need spark plugs as well... Thank you TW
  18. mini_racer
    Engr Manager
  19. GreyLens
    GreyLens New Member
    259
    71
    Electrical Engineer
    San Antonio, Texas
    #39 GreyLens, Sep 22, 2010
    I see you recommend we follow Mini's recommendations for plugs for the R56. I've been searching for info for plugs for the R56 Factory JCW and can't find any good info. Doesn't Jan have a recommendation? I'd like to get an upgrade plug if there is one that is worth it.
    If not I assume the NGK ILZKBR7A-8G used in 2009 Cooper S's is good for the 2009 Factory JCW?
  20. mini_racer
    Engr Manager
    #40 mini_racer, Sep 28, 2010
    Jan has not indicated a recommended spark plug for the 2nd Gen cars different from the OEM recommendations. So, just get a new set of your OEM plugs for peace of mind and you will be good to go.
    Also, I want to make sure that you know that we will all walk away with a hard copy of our dyno plots. If you have a flash drive bring it if you want to get the data for your runs. You can go to the dynojet site and download/install the PC app for the dataset.
    http://www.dynojet.com/downloads/software.aspx
    Alternatively, I can email your dyno run datasets to you after the tune.
