RMW's Project X-1
Discussion in 'Car Builds, Projects, Idea's Experiments' started by Jan, Jan 4, 2015.
  1. Jan
    Jan Well-Known Member
    377
    382
    big day of plumbing , 1 more to go to finish the lines
    getting there:
    Quit scuring around and get to work! It's almost time for the Dragon!
  3. 00Mini
    Very impressive !!
  4. Dave.0
    Perfection takes time and those that have patience are rewarded in the end. :Thumbsup:
  5. BlimeyCabrio
    Ancient Philly Proverb
  6. Dave.0
    If you rush it you end up with a Spintex and a car on Jack-stands for a few years.
  7. Jan
    377
    382
    7 point Mastercraft/Impact racing harness in
    Overflow tank in
    Final set of Race Pak switches in
  8. Jan
    377
    382
    Dual Aeromotive fuel filters for Aeromotive fuel pumps (Look closely R56 electric steering rack in there)
    Link Flex Fuel sensor to run E85
    Aeromotive rising rate fuel pressure regulator
    Racepak Smart wire system: And Racepak Switches
    [​IMG] [​IMG]
    Mastercraft/Impact Full Carbon seat with 7 pt racing harness
    Securely mounted: [​IMG]
    Vipec i88 stand alone
    RMW Return fuel systems with Racepak pressure sensor
    Tilton master cylinders with Racepak pressure sensors for data logging
    Setrab gear box cooler and engine oil cooler
    Outside looking in: Air is forced through the coolers
    Who doesn't love a Borg Warner twin scroll turbo shot?:D
  9. Dave.0
    Turn the key / flip the switches and start it.
  10. ScottinBend
    At first glance at the first picture my thought was "Damn, that's a bigger car than I thought!"
    :D
    oh, and of course........:drool
  11. Jan
    377
    382
    same length, just wider
  12. ScottinBend
    And a much smaller driver.....:D
  13. Jan
    377
    382
    Custom Tarett Engineering Cockpit adjustable swaybars front/rear :D
    Tarett Engineering blades and controllers with Custom RMW swaybars and mounts
  14. 00Mini
    Amazing craftsmanship !!
  15. RallyMini370
    The problem with this project is the quality and finish is way too good. I've tried not to look because I've super jealous.....if only I could weld like that. Jan you make me sick..LOL Make Markus some control arms he can't break!
  16. Jan
    377
    382
    I would but the shop working on it has their own way
  17. Firebro17
    This project is so cool, I can't express my feelings well enough without using obscene explitives and risk censorship!
  18. Jan
    377
    382
    Wiring harness going in along with the 2.0L RMW Deck Plate engine.........
    OS GIKEN Twin Disc billet clutch/flywheel
    Waiting for it's 2.0L stroker to jump in: :p
    Wheel Speed sensors in
    Brake Pressure sensors in along with balance bar
    Sadev Sequential box with hydraulic throw out bearing
    Custom 300M sway bars with Tarett Engineering blades
  19. Dave.0
    More Race Car Porn :drool
  20. ScottinBend
    Fuel cell is made just up the road from me. Took a quick tour awhile back, very nice facility.
