Rubbing Compound
Discussion in 'Detailing' started by Justa Jim, Apr 15, 2012.
  1. Justa Jim
    Wake up Lotise, this is in your forum. :D
    I just finished touching up some dings with a paint pen. Normally, I would use "rubbing compound" next to level things out, but I have read here that it is NOT good for clear coat. Is there something else that would work?
  2. Justa Jim
    Hummmm, once again I ask a question that nobody can answer. A pattern is developing here. When I find the answer I will post it, so every will know. :nonod:
    Do not use the old fashioned rubbin compound on your MINIs paint. It will really screw up the clear coat. FWIW I do not bother trying to rub down places I use touch up paint on. I use a paint pen & it does not blob like touch up paint put on with a brush.
  4. Steve_LV
    Steve_LV New Member
    Mar 2, 2012
    Las Vegas, NV
    If you've got light scratches in your clear coat, how do you get them out if you can't use rubbing compound? I just bought some "hand polish", which I assume is the same thing, but I haven't used it yet.
  5. Austinsynthetics
    109
    44
    California
    #5 Austinsynthetics, Apr 16, 2012
    This may answer your question.
    MOTHERS® Polishes·Waxes·Cleaners
    Can be picked up at any auto parts store, or from us at wholesale prices.
    Brett
    P.S. Another good product is Swirl Remover made by 3M, it's a very smooth polish.
  6. Octaneguy
    Octaneguy New Member
    Apr 24, 2009
    579
    31
    Dream job
    Anaheim, CA
    Jim,
    Check out my article
    The Best Car Care Products are at ShowCarSupplies.com - Technique is Everything
    Your question is answered in the first paragraph. I'll quote the first paragraph here:
    "If you're new to detailing, you need to learn the lingo and strike some common phrases from your existing vocabulary. If you work by hand, and working on a modern paint finish, forget about "Rubbing Compounds" as well as "Wet Sanding". It's not that these terms are not important but simply because they are commonly misused which can lead to confusion and potentially irreversible damage to your paint. We will talk about safer alternatives that will get the results you seek without the risk."
    Read the rest of the article here
    What you are asking about is hand applied polish. A safe and effective polish is Prima Swirl. I use this by hand a lot to remove minor clear coat blemishes and smoothing down touchup. We also used it the other day to clear up some lightly fogged headlights on a BMW 535. It also works great to clean up neglected or environmentally contaminanted vinyl. The link below has a picture of such a cleanup on perforated vinyl on the sunroof of a MINI.
    The Best Car Care Products are at ShowCarSupplies.com - Polish for removing swirls
    I would just use a dab of Prima Swirl on the end of a microfiber towel and gently polish the touchup. Although now I am using an entirely new system from a company called Applied Colors that lets me smooth and apply touchup using a chemical that works better than Dr. Colorchip or Langka.
    Richard
    Thanks for setting us straight Richard. To a non-paint detail professional it can seem so confusing.
  8. Justa Jim
    Thank you very much Richard. I look forward to meeting you at MOTD and buying some items. :)
  9. CHKMINI
    Thanks Richard. I read your articles a couple of days ago and used Swirl to remove some bug marks from my Clear Bra. It worked great!
  10. Octaneguy
    Apr 24, 2009
    579
    31
    Dream job
    Anaheim, CA
    It really is confusing. There are soooo many products out there, and its really hard to choose the ones that work best. I went to the website quoted in a previous post here for Mothers and if I were a newbie...the sheer number of choices of products is mind boggling. I've always recommended Prima because it's simple and effective and if it's good enough for a $120,000 Fisker Karma, it's good enough for our MINIs, lol. And for those that don't know...we are Fisker Automotive HQ's exclusive detail shop for all of their press and prototype Karmas.
    https://www.facebook.com/media/set/?set=a.10150806614276133.471932.157160866132&type=3
    If you had unlimited funds to build a dream garage for your MINI, it might look like this
    And look what products are used
    See more here
    https://www.facebook.com/media/set/?set=a.10150808066841133.472093.157160866132&type=1
    Jim..are any of you that's going to MOTD might be interested in our Sonax Full Effect Wheel Cleaner? I'm thinking of shipping some but not sure if people will be interested in a wheel cleaner that's basically touchless...spray and rinse?
    Awesome!!! Thanks for sharing. :cornut:
    I want some!
    So yeah, bring it please. At least one bottle for me.
  12. Octaneguy
    Apr 24, 2009
    579
    31
    Dream job
    Anaheim, CA
    Ok Nathan. :biggrin5:
    Richard
  13. Justa Jim
    Count me in on the wheel cleaner too.
  14. Octaneguy
    Apr 24, 2009
    579
    31
    Dream job
    Anaheim, CA
    Got it...thanks for the headsup.
    Richard
  15. eMINIparts
    eMINIparts Well-Known Member
    3,751
    1,087
    MINI Parts Advisor
    Bedford NH
    If you look at Nates Garage he must have 10 different sets of wheels is 1 bottle gonna be enough?
  16. Justa Jim
    I guess you will have Black Wow with you as well?
  17. Crashton
    Richard if you could reserve me some Sonax wheel cleaner I'll be there to pick it up on Friday.
    Thanks! :)
  18. Metalman
    That SONAX Ultimate Wheel Cleaner is magical stuff......
    I bought the spray which is almost gone and fortunately I also bought the 5L refill tank.... So now I'm hoarding it to be used only on my MINI......:D
  19. Octaneguy
    Apr 24, 2009
    579
    31
    Dream job
    Anaheim, CA
    Haha, he'll need the 5L refill, but I'm not so sure I'll be sending any of those up with me. If no one buys it, I'd rather use it up than ship it back, lol, cause they are heavy.
    Absolutely...but Way Motor Works and MC2 magazine will also have some.
    Will do! I guess I'm getting enough feedback that I should ship some product to the event, lol. I'm flying in, so I can't really pack this stuff in my suitcase, lol.
    Richard
  20. CHKMINI
    With 1100+ registered I'm sure that a lot of product is going to leave the Dragon with happy buyers! I talked to another vendor yesterday who also shares my view and is going to have more product for sale than he normally has at MOTD. Richard, I'm in for Sonax and Black Wow....looking forward to meeting you.
