Sap
Discussion in 'Detailing' started by Apok, Aug 20, 2013.
  1. Apok
    Apok New Member
    Jun 15, 2013
    776
    357
    How do I get sap off my poor mini? My parking spot at my new house is sadly under a tree that keeps dripping sap all over the place. What can I do other than cut the damned tree down?
  2. 05r50
    05r50 Well-Known Member
    Dec 4, 2010
    1,269
    696
  3. MCS02
    We had that problem. It is real bad on paint. We cut them down.
  4. Apok
    Apok New Member
    Jun 15, 2013
    776
    357
    Id hate to cut down such a nice big tree. It was probably planted when the house was built back in the 60s. But it def needs trimmed back.
  5. mini_racer
    mini_racer Well-Known Member
    Engr Manager
    Nail polish remover is a very strong solvent, it would be best for your paint NOT to do this. I believe this is basically Acetone.
    If they are small then you can clay bar them off. If larger then use a mild solvent like mineral spirits or GooGone.
    Unless you used a car polish product with wax in it to remove the spots, you will need to come back over the areas with a protective wax coat.
    You should also spray the tree regularly to kill the bugs drooping on your car, if in fact that is your situation.
  6. Metalman
    I've used WD-40 to good results.... I have two large pine trees out front.... Sometimes they've been known to weep sap...
  7. nxtMINI
    nxtMINI Active Member
    Apr 26, 2010
    405
    40
    Michigan
    I've used rubbing alcohol in the past... worked good too.
  8. BRG_Paul
    BRG_Paul Active Member
    Nov 20, 2011
    758
    184
    Turbomachinery Engineer
    York, PA
    +1 on the WD-40. It works very well for me too.
  9. TheModFather
    Lighter fluid... The cheap stuff! It works and dries better than WD. ;)
  10. ScottinBend
    Well since WD40 is basically kerosene and oil.......:)
  11. Dave.0
    When you are done, do not park under the tree again.
  12. TheModFather
    ^^^ That always helps!
  13. Apok
    Apok New Member
    Jun 15, 2013
    776
    357
    I'd park in the garage, but since we just moved in, its full of stuff that doesnt have a new home yet. Though now that the dumpster is gone I can get out from under the tree. Thanks for the info guys! Ill try out the WD-40 this evening since I only have one little spot left. The rest popped off with a little pressure from a finger nail.
  14. Dave.0
    Very warm water on a towel works really well to make the SAP liquid again and you can wipe it right off. It's it's fresh and not baked on for months.
