Interior 2nd Gen Scan Gauge 2 Questions
Discussion in 'Tuning and Performance' started by genik, Aug 5, 2013.
  1. genik
    genik Member
    Feb 20, 2012
    402
    19
    1. What kind of info can i derive from the car if i purchase a scan gauge 2?
    2. Will it read CEL errors?
    3. What is the best place to place it in the interior of my car?
    4. Where from can i purchase it as cheap as possible?
    5. Is there ScanGauge 3 coming out?
  2. ScottinBend
  3. rum4
    rum4 Club Coordinator
    4,568
    1,475
    SC
  4. genik
    genik Member
    Feb 20, 2012
    402
    19
    rum4 thanx for the contribution, can u send photos so we can see where you mounted the velcro?
  5. AliceCooper
    AliceCooper Club Coordinator
    Mar 13, 2010
    643
    123
    CT Technologist
    South Florida
    I purchased mine on Amazon, at the time it was the best price I could find.
  6. Firebro17
    I'm very happy with my Scangauge. I mounted mine directly beneath the switch panel in the center console of my R53 with double sided tape. I like it there because it looks like it belongs there. If you like, check out the picture of it in my gallery of MINI photos.
  7. ScottinBend
    You can check my gallery for some pics of my setup.
  8. rum4
    4,568
    1,475
    SC
    I'll post one later
  9. genik
    genik Member
    Feb 20, 2012
    402
    19
    thanx guys but just remember that im looking for scangauge R56 setups cause i need to get ideas for my R56 interior :wink:
  10. ScottinBend
  11. rum4
    4,568
    1,475
    SC
    pics as requested
  12. pmsummer
    pmsummer Well-Known Member
    Apr 3, 2012
    570
    400
    Semi-retired planner
    Mounted mine on the right knee bolster. I used 3M Industrial Dual Lock material. Much better hold than Velcro.
    After having it reprogrammed for MINI, I am currently running boost, voltage, coolant temp, and oil temp.
  13. UKCoopeR
    UKCoopeR Active Member
    May 21, 2009
    293
    109
    VA,USA and UK
    I used to have mine mounted down low where it didn't look out of place. But found that i couldn't read it safely. I switched to the cravenspeed mount, it looks a little more aftermarket but is actually readable!
  14. minirab
  15. Way Motor Works
    Way Motor Works New Member
    206
    MINI Tuner
    Atlanta
    FYI if you get your ScangaugeII from WMW it will come preprogrammed with the special MINI codes:
    TFT- Transmission Fluid Temp (Auto Trans ONLY)
    EOT- Engine Oil Temperature
    A/F- Air Fuel Ratio
    FRP- Fuel Rail Pressure (PSI)
    ENG- Engine Temperature
    If you get it from anyone else you will have to ship it back to scangauge and pay $25 to get it upgraded with this programming.
  16. pmsummer
    Apr 3, 2012
    570
    400
    Linear Logic will flash/reprogram a recently-purchased ScanGaugeII, and ship it back to the owner, free of charge.
    Had I known that Way sells them "pre-flashed", I would have bought mine from him instead of AutoZone, to both save me the hassle (and slight cost) of shipping, and to support a small business who supports MINI owners. But Linear Logic will reprogram a newer (software version #) free as a courtesy, or at least they have been doing so. Contact Linear Logic/ScanGauge with questions.
  17. Metalman
    ^^^ This is true and they did this for mine at no charge...
    Interesting fact... I kept getting two strange codes that would clear but would always come back (don't remember which ones they were now).... After the MINI specific software reflash on the SGII, the strange codes haven't resurfaced....:D
    My mount (no visible power lead.... kinda)....
  18. ScottinBend
    Anyone have any codes for the R53?
  19. rum4
    4,568
    1,475
    SC
    Metalman did you make that mount?
  20. Metalman
