I am looking for some help in setting up my Scan Guage II. I have seen several posts on setting the unit up to give accurate boost pressure readings. My problem is the process for entering these changes into my Scan Gauge, if it is a type that can be modified? So any help for a novice would be appreciated.
Look in your scangauge manual - under Xgauge programming - has the step-by-step process for setting up an x-gauge. Then use the values provided in the other threads. Starting on page 24: http://scangauge.com/support/pdfs/SGMan5_1.pdf Or here: ScanGaugeII - Add-A-Gauge
