Scan Guage II - Oil Pressure??
Discussion in 'MINI' started by Justa Jim, Aug 7, 2010.
  1. Justa Jim
    Is there a reading for oil pressure on the scan guage????? I can't seem to find it in the manual.
    Water temp seems to hold around 220 and intake air around 109. Does that sound like what the rest of you are getting??
  2. lotsie
    400
    stagehand/part time detailer
    Right here
    Sounds about right. Coolant temp will drop if max A/C is on. Our intake seems to be about 10-15 degrees above outside air temp, when moving. Could be wrong, but I don't think there is an oil pressure sensor on the car.
    Mark
  3. CHKMINI
    3,801
    Correct...no oil pressure with the scan gauge. Water and intake temps are what I see with mine.
  4. Justa Jim
    Thanks guys. I guess all is well, but I wish here was a oil pressure guage. I'm not comfortable with with just the light.
  5. Justa Jim
    Since there is a MAF, can it read air flow in order to determine if one type intake gives more air then another?
  6. lotsie
    400
    Right here
    One would think so. I wish I'd logged the MAF on our Clubman before the JCW went in:rolleyes5:
    Mark
  7. Justa Jim
    Got any idea how to do it???? I know someone talked about reading boost on the scan guage. On a N/A engine wouldn't that just be air flow???
  8. lotsie
    400
    Right here
    It would just be air flow on a N/A engine. I don't really know much about the Scangauge. I was was just going to write down numbers as I saw them on the Garmin, gut never got around to it. I guess you could wrap something over a small amount of any filter, and see if the air flow drops as a test.
    Mark
  9. Justa Jim
    Thanks Mark, but I did a search (clever idea, eh) and found the answer. I'll keep you posted on the results. Good luck at the dealer tomorrow and have a great trip to MITM/MTTS. I'll be looking forward to some intresting reports and don't forget the dog bickies. :Thumbsup:
