Interior 2nd Gen Schwaben 14020SCH BMW/MINI Scanner - Window Reinitialization and Activation
Discussion in 'Tuning and Performance' started by Rainman768, Apr 9, 2017.
  1. Rainman768
    Rainman768 Active Member
    167
    81
    For an unknown reason the passenger window on our clubby stopped returning to the fully up position* when the door was closed. So I checked to see if that could be reset with the Schwaben scanner. I found the reinitialization process and that did the trick. The window now goes all the way up when the door is closed.
    To do so follow these steps. (Note: There will a few informational windows which you need to hit F1 for okay to continue.)
    On the scanner navigate to the Main Group.
    From the Main Group choose:
    3 Service --> 4 Body --> 1 Locking and security functions --> 3 Power windows
    Then select the desired door and follow the instructions. Choose End service when done.
    Before I found the reinitialization function I found the component activation section to roll up and down the windows. This could potentially be useful for troubleshooting.
    From the Main Group
    2 Control Units --> 1 Body --> 20 FRM Footwell Module --> 7 Component activation --> Power window front
    and then choose to open/close desired window.
    Note: in the Component activation window, option 1 is to Reset control unit. I'm not sure what it does but I tried it anyways. What I did notice is that the driver's window would no longer return to the fully up position when closed. Reinitialization fixed it as well.
    *This is regarding that auto dip or whatever feature it's called when the window goes down a bit when you open the door and then when you close it the window returns to it's previous position. In this case the window just kept going down a bit but never up.
