Engine Drivetrain 2nd Gen Seafoam = Check Engine = Will Not Clear
Discussion in 'Tuning and Performance' started by Justa Jim, Aug 30, 2010.
  1. Justa Jim
    Bingo, all is right with the MINI again. Thanks for the tip.
  2. Metalman
  3. Dr Obnxs
    Dr Obnxs New Member
    Jun 11, 2009
    1,158
    Yes and no
    the downfall of the DI engine with respect to carbon build-up is that the gas doesn't clean the back of the valves. But it also seems that the early Prince engines had crappy phase separation out the valve cover, so they are dumping way too much oil into the PCV lines anyway. On the Tritec, carbon build-up is a problem, but a much slower one than the DI Prince.
    Matt
  4. Justa Jim
    Doc, I saw the vedio about seafoam here and it was being put in a justa, but I guess it was a 1st generation. I have a 2009 justa, so do I not have to be concerned about the carbon since it is not DI??? I'm unclear on this.
  5. cal330ci
    cal330ci New Member
    Aug 30, 2010
    38
    Automotive Technician
    Vancouver BC
    The DI carbon/sludge/Oil deposit problem has been an issue for quite a while. There are companies like BG that make their own chemical treatment and have their own solutions to this problem. I have seen the Audi/VW treatment but these services are basically sold to the customer as an optional procedure. I have been promised a BMW treatment but it looks more like somewhere around December until anything I see anything new.
    I know the treatments do not remove the build up from the back of the valves. Since its not all carbon build up the deposits are actually not that hard and they can actually flake off with the proper cleaning tools. I know dealers are sending the heads out to be cleaned, decked and all the valves checked etc... Removing the head everytime this problem occurs is excessive. To be honest I don t know what the ultimate solution will be. It is a serious problem. The good thing about R56 Cooper S is the intake manifold can be removed pretty quickly and about 90% of the carbon can be removed without removing the cylinder head.... with the proper tools. Obviously if anything new happens I will post
  6. Justa Jim
    That was an interesting read. The Justa develops 103 ft pounds of torque at 2K where the "S" gets 177 at 1,400.
    But my question still remains unsnswered. Does the fuel wash the backs of the valves in the Justa, making Seaform un-necessary????? I come from the days of points and condensers.
  7. Dr Obnxs
    Dr Obnxs New Member
    Jun 11, 2009
    1,158
    It's not as required
    but there is no "yes" or "no" answer. To some extent, the sea-foam on the port injection is not needed, but even with the Tritec, carbon build up would lead to issues, just not like those experienced with the turbo Prince.
    So if you don't do it on the N/A Prince, you won't build up carbon to the point where the engine will kill itself. That said, it still injests more oil than it should.
    Lynn would say blow off the Sea Foam and just use water on a hot engine.
    Anyway, decarbonizing isn't new with the MINI. It's an old, old technique.
    Matt
  8. Justa Jim
    Thanks Doc. At least I know the smoke was not something buring off that should not be. From what you say, I take it that Seafoam is a good thing, but not needed as often as the with the "S", on the Justa?
  9. Dr Obnxs
    Dr Obnxs New Member
    Jun 11, 2009
    1,158
    Yep....
    that pretty much sums it up.
    Matt
  10. tptv
    tptv New Member
    Apr 8, 2018
    This is incredible advice after days of trying various things. I now have new plugs and have switched coils (to no avail, lol), and NO CEL! Thank you! This worked!
  11. Sully
    Sully Administrator
    Jul 21, 2015
    Software
    30350
    Good deal.. glad it worked and welcome to MA. :)
  12. tptv
    tptv New Member
    Apr 8, 2018
    Thanks! And thanks for the welcome, looking for more stuff, lol! Guess I should change my pic, huh?
  13. Sully
    Sully Administrator
    Jul 21, 2015
    Software
    30350
    Good deal - let us know if you cannot find what you are looking for. Regarding the pic - nope looks good. :D
  14. MCS02
    Welcome to MA. don’t bother trying a search. If you have a quest just ask we will try to answer it. We never tell people to do a search here.
  15. Dave.0
    Yes, welcome to M\A and just ask any questions and we will answer.
    Just don’t ask us what color “eyelashes” you should put on your MINI . Hahahahahaha
    Dave everyone knows the best ones are hot pink. :cool:
  17. Sully
    Sully Administrator
    Jul 21, 2015
    Software
    30350
    Those are pretty! :D
    Sully JCW ones are red.... :Stig:
  19. Sully
    Sully Administrator
    Jul 21, 2015
    Software
    30350
    Good point.. I'll have to see if I can find some. :D
