Show off your Classic
Discussion in 'Classic Mini' started by MinixB, Jul 19, 2010.
  1. CHKMINI
    VERY nice!!
  2. travellering
    travellering New Member
    Nov 16, 2009
    Only four months late with this tidbit, but if your headlight is on but inexplicably dim, it's not actually on. The British minis have the parking/side lights hidden behind the headlight, shining through a clear section in the reflector. I have had a lot of troubles with the wiring on my headlights, with the connector at the back of the light shorting out so bad it melted. Then the light switch inside the car somehow shorted against the top of the heater box. That one was incredibly frustrating, as it would work fine as soon as you drop the heater to test the wiring! Now I seem to have a problem with either the wiring to, or the actual dim/dip switch on the floor. Same net result though, everyone tells me the low beams are on, just really dim. It's just those parking lights shining through again....
  3. Firebro17
    Great info!
  4. Firebro17
    #64 Firebro17, Jun 25, 2013
    Here's a few shots for your photo collage Dave...
  5. Firebro17
    And another...
  6. Minidave
    Ah yes, but US Minis don't have those park lights in the headlights, ours use sealed beams, which have a high and low beam (dipped) built in, but no park lights. On our cars the park light is in the turn signal - they light up steady, with a second element that's brighter that lights up for turns. I maintain she has a bad ground, that's usually the cause of a dim headlight.
  7. Minidave
    Is the white Mini a Vtec?
    If so, details please....if not why do the wheels stick out so far?
  8. Firebro17
    #68 Firebro17, Jul 19, 2013
    No V-Tech in Craig's near flawless Panel. I don't remember if it's a 1293 or 1380 that was built by Brian Waters, but it runs better than most street cars I've seen. The wheels are 10x6 Mambas w/o spacers on an all Cooper S brake set-up. Take a look at post 64 above and you'll get a glimpse of the side of both cars...
    On our next track excursion, my buddy with the MGB ought'a have his Panel out there to add to the mix. Here's a teaser pic. He'll be posting some detailed shots before too long, I'm sure. :beer
  9. barefootnozza
    barefootnozza New Member
    Jul 27, 2013
    10
    13
    My lady and I bought this on Tuesday and got it legally on the road today...I'm in the process of learning how to fix minis now because we have had a couple of small niggles but it's quickly becoming a passion of mine (I've always been useless at DIY in the past but maybe I never had a reason to attempt it before)...first job is to replace the carb float arm thing, put a matching wing mirror on and add some interior trims, then I'd like to learn about the engine in more detail :) We are already in love with her, we just need to name her now...any suggestions??
  10. Firebro17
    #70 Firebro17, Jul 27, 2013
    Nice car! Where do you guys live?
  11. barefootnozza
    Jul 27, 2013
    10
    13
    Thank you, we live in Leicester which is in the Midlands
  12. Firebro17
    Here's a shot from this past weekend's car show.
  13. joltfreak
    joltfreak New Member
    Here are mine:
    The green one (haven't been able to name it)
    The V8 mini beastie
  14. Nathan
    The Beastie looks rather sinister.
  15. BruceK
    BruceK Active Member
    Feb 24, 2015
    Texas
    Here are some photos of my Mini getting a state inspection a couple of months ago, right after I imported it. That was the first part of the registration/licensing process. No, it didn't fall through the hole in the shop floor! The state inspection was easy, but I really got the run-around with local police departments in trying to get one of them to actually look at the car and inspect the VIN (necessary because it had foreign paperwork). Finally got a detective to verify the VIN and then I gave the DMV a stack of paperwork to satisfy them. The state's happy, and I'm happy.
    As for the car, it's an '88 Austin Mini (and it really is an 1988 model - I wanted to made sure it was completely legal for import under the 25 year rule so I didn't have to worry about the feds potentially coming after it later on). This is the 7th Mini I've owned and for this one I basically commissioned the car to be built to my wishes by a good shop in the UK. I chose the white color as my first car was a white Mini when I was 17, so this is nostalgic for me.
  16. Firebro17
    Brilliant looking! Thanks for sharing Bruce.
  17. Spa2k
    Spa2k Well-Known Member
    May 9, 2013
    1,955
    975
    Iowa
    Hey, Bruce - I'd love to hear more about the process you went through to get the car here. How did you hook up with the shop over there?
  18. Minidave
    Bruce, that looks just like the inspection station I had to take Buzz thru to get his VIN verified before I could license him.....
    I'm surprised I hadn't posted a pic of Buzz in this thread yet......
  19. Firebro17
    Those are sure nice looking wheels you've got there!
  20. Minidave
    The gold really adds something to the look of the car, I'm not normally a gold wheels fan, but since the rest of the color is so bland, they do help!
    I don't think it would look as good with black or even silver wheels....
