Engine Drivetrain 1st Gen Cooper S Simple question: How much torque on Plugs
Discussion in 'Tuning and Performance' started by Sin MINI, Jan 1, 2011.
  1. Sin MINI
    Sin MINI New Member
    Jan 1, 2010
    15
    Las Vegas, NV
    Yes, I did a search. Nothing
    Can anyone tell me proper torque wrench setting for spark plugs? I bought a cooler set and need to install them.
    Any tips for someone who's never changed plugs before? Is it any more complicated than old plug out/new plug in?
    Tip #1.... Do it with a cold engine!
    Tip #2.... Pull the plug wires by the boot not the wire.
    Tip #3.... If they are hard coming out, crank them back in a 1/4 turn & then back out. Keep doing that until they are out.
    Tip #4.... I always use a very tiny bit of anti-seize on the plugs. Some folks choose not to.
    Tip #5.... I use 21 FT/LB of torque.
    These tips are for an R50-R53 MINI.
  3. Nitrominis
    Nitrominis Banned
    61
    Doing nothing
    Santa Cruz, CA
    Naturally I am always curious why the cooler spark plugs???
    Tip #4 very important...... use anti seize always.
    Confirm with the **manufacture of the spark plug if there is any specific torque value for their spark plug other wise use BMW/MINI specifications for your year and model..
    Factory for 2002-2005 Cooper and S... **Spark Plug to Cylinder Head 27 Nm (20ft-lb)
  4. Ofioliti
    Ofioliti New Member
    35
    Professor
    ... always curious
    Yet another tip...
    When screwing in the new plug, I use a firm straw attached to the top of the plug. It makes it easier to feel the plug screwing in properly without striping it. :Thumbsup:
    (Of course, torque it properly with the wrench after finger-tightening it with the straw.)
    Very good tip!:Thumbsup: I use a rubber tube thingymabob that the MAC tool guy gave me years ago. It makes it so much easier to start the plugs back in.
  6. minimark
    Good tip!
    Some even use a section of fuel line hose...
  7. mini_racer
    mini_racer Well-Known Member
    Engr Manager
    As mentioned in the other thread at the other place, 1st Gen cars spec 20ft-lbs (27NM) of torque for the plugs.
    I have seen several lively debates on the use of anti-seize mainly centered around side effects such as heat transfer and torque settings. MINI does not spec to use it but many do anyway. I personally use just a tiny bit, unless I think there is still enough on the threads in the head from last time.
    Wire removal and corrosion tip:
    - Use a back and forth twisting motion when you grasp the boot to remove the plug wire. Just push straight on for reassembly.
    - On many cars the terminal at the coil for the #3 wire corrodes. You might want to take the wires off one at a time, and wire brush the terminals.
    - I reassemble with a dollop (maybe the size of a small pea) of dielectric(Silicone) grease on the coil terminals as well as the spark plug terminal.
    - Also, I make sure to tighten the Aluminum terminal on the spark plugs, they always seem loose on a new plug.
  8. Dan@GrassrootsGarage
    Sep 30, 2009
    26
    Thomasville NC
    NGK specifies 30Nm on the box, BMW TIS specifies 27Nm so that gives a range of 20-22 Ft.lbs. I use 22 personally and only a small amount of anti-seize.
    part of the job of the spark plug is to remove heat from the cylinder. The heat range refers to the amount of heat that the plug can remove, so a colder plug removes more heat, a hotter plug removes less. When we increase the amount of boost (via smaller s/c pulleys) we also increase the amount of heat created, so it needs to be removed to maintain an optimal cylinder temp.
  9. Thumper460
    Thumper460 Active Member
    May 26, 2009
    559
    94
    United States Navy ..Retired
    Dan@grassrootsGarage.. about time you started Posting!! Good to know!!
    Now back to the thread..
    Just me......................
    Thumper
  10. ScottinBend
    Depends on the plug......if the plug has a crush washer (most do) then it is about 1/4 turn past finger tight. If it has no crush washer it is about 1/2 turn past finger tight.
  11. Nitrominis
    Nitrominis Banned
    61
    Doing nothing
    Santa Cruz, CA
    #11 Nitrominis, Jan 2, 2011
  12. jiminni
    jiminni Well-Known Member
    262
    Ca.
    So has anyone used these yet? They do look interesting. Not sure why the pics are so big? They came off my iPhone.
  13. Nathan
    I've used them, was not really enamored with them at the cost. Pulled a 10K miles and the looked like crap, went back to a less expensive NGK and happy.
  14. ScottinBend
    +1 NGK JCW oem plugs
  15. jiminni
    262
    Ca.
    Thx for the info :Thumbsup: I will stay away from them also.
  16. jimz68
    jimz68 New Member
    May 11, 2009
    16
    Hmmm.......
    I've had really good luck with mine.
    Like them better than the NGK's.
    Oh! And to stay on topic, 20-22 Ft-Lbs for me, too.
