Soon to be F55 owner
Discussion in 'Starting Line - New Member Introductions' started by Bobby D., May 27, 2015.
  1. Bobby D.
    Bobby D. New Member
    May 27, 2015
    Retired Electrical Engineer
    Indiana
    Newbie here, waiting on delivery of a 2015 5 door non-S. I've been reading up on minis, and have a concern about direct injection. Does the 1.5 liter engine have a problem with carbon build up on the intake valves?
    Bobby D.
    6,278
    Welcome to MA!
    Cant help with the question but someone will be along that can.
    So far there haven't been issues with the new 3 cylinder that we've heard much about at all. It was the previous N14 that was problematic, the later N18 is better. Your's is different than those.
    Your's is a BMW designed lump used in BMW's as well as MINIs. The previous generation used a Peugeot/BMW design.
    Welcome...
    It is early days for the 3 hole MINI engine. Many makes are having issues with carbon buildup in their direct injection engines. Hopefully MINI has fixed that issue, but if not it is just a service that you do. I wouldn't worry about it.
  5. nxtMINI
    nxtMINI Active Member
    Apr 26, 2010
    405
    40
    Michigan
    Welcome to M/A!
    ^^ I agree with what they said about the engine :biggrin5:
  6. mrntd
    Welcome Aboard!
  7. Zapski
    Welcome! Enjoy the ride!
    Speaking as someone who has an N14 engine, the carbon buildup issue wasn't as awful as I'd been fearing. I had over 100,000 miles on mine before I had a real issue with it. Some of it can be dealt with by driving habits; avoid frequent sub-20 minute drives and it should be OK.
    Still, as the others have said, you've got a totally new design that we don't have a lot of experience with. Should be fun learning!
  8. DryMartini
    DryMartini New Member
    Dec 6, 2012
    1,048
    479
    Welcome aboard!
  9. Ryephile
    Ryephile New Member
    Apr 9, 2009
    299
    122
    Yes!
    Metro Detroit
    Every generation of GDI engine has been getting better for valve deposits via improved air-oil separators [aka catch cans] in the valve cover. The 1st gen VW FSI's are notorious for bad carbon deposits, as is the MINI/PSA Prince engine, however big wisdom strides in crankcase ventilation have happened since those engine designs and I'd hazard the B38 you'll have in your MINI will be able to go muuuuch further before needing a cleaning.
    Given OEM's must comply in not venting anything to atmosphere other than the tailpipe, it's also likely that an aftermarket solution [catch can] that simply vents the AOS to atmosphere instead of back into the intake would help carbon build-up at the expense of greater overall vehicle emissions [if you care].
    Basically, I wouldn't worry about it. If the engine needs a cleaning every 100k, I would call that acceptable maintenance.
