2nd Gen Coupe Sound when Applying Brakes
Discussion in '2nd Generation: 2007+ R55 through R61' started by friendraja, Mar 17, 2016.
  1. friendraja
    friendraja Member
    Aug 31, 2015
    System Administrator
    Dublin, ohio
    Guys,
    My JCW coupe was lying unused frm last 3 weeks, as i was on a Vacation. Today, when i started the Car, it went normal. I let the engine run for 10-15 mins, then tried to reverse the car. I heard a strange sound, like someone hitting the car with metal, the car was not smooth after that n when i apply breaks the breaks make full noise , there is a vibration felt on the steering.. vehicle is taking time to stop even at a speed of 30-35 mph
    Even the engine sound is different, its dead silent when i am driving..i
    Any idea, what caused to this?
    Thanks,
    Raj
    If you left the parking brake on it may have stuck. The noise you heard was it letting go. Also the brake disks may be a little rusty from sitting. If so they will get quitter after a few stops.
  3. mrntd
    MCS02 has it that the brakes just got a little rusty sitting still. A couple of good stops will clean them up. The vibration may be from the tires getting a little flat spot from sitting. Once they get up to temp on the highway or back road they'll be fine. Though you may want to check your air pressure.
  4. ZippyNH
    Rusty brake rotors....happens on most any car...
    Go drive and polish those rusty things up!!!
  5. Grizld700
    Grizld700 Well-Known Member
    Feb 2, 2016
    1,212
    47
    Eastern Iowa
    Perform Italian tune up and brake moderately while doing it.
    Normal, drive easily until it goes away, then nail the throttle. :arf:
  7. friendraja
    friendraja Member
    Aug 31, 2015
    Dublin, ohio
    Thanks guys..will try these out..
