1st Gen R53 Cooper S Speed limiter for the '03 MINI Cooper S?
Discussion in '1st Generation: 2002–06 R50, R53 & 2004–08 R52' started by oldvet53, Oct 29, 2012.
  1. oldvet53
    oldvet53 New Member
    Oct 21, 2012
    277
    79
    Disabled/Retired
    N.E. Arkansas
    Does anyone here on the forum know what the speed limiter is set for on the 2003 MINI Cooper S? I know it is 135 mph. on the new Cooper S but didn't know if it was different for the 2003 with the Supercharger.:confused5:
    I have never gone fast enough to find the speed limiter. 125 at the end of the Mid-Ohio straight. It is more than that I'm sure.
    It is the same on the 2003, 135mph...
    Getting to 135 is not easy either, remember a MINI is essentially a brick.
    I've seen a GPS indicated 135 only twice. On the back straight of Road Atlanta and on I-10 in New Mexico where the road is straight as a chalk line and it looks like you see from AZ to TX.
  4. oldvet53
    oldvet53 New Member
    Oct 21, 2012
    277
    79
    Disabled/Retired
    N.E. Arkansas
    Thank's Crashton and Nathan. I've had mine to 120 mph. so far but had a curve coming up so had to back off. Thanks for the info.
  5. Dave.0
    If you get a tune you can have it removed. I have done 141 Mph.
  6. oldvet53
    oldvet53 New Member
    Oct 21, 2012
    277
    79
    Disabled/Retired
    N.E. Arkansas
    After I do the oil change in the Supercharger and get the 15% pulley and belt from WMW I'll drive the 125 miles to get it on a Dyno and a tune.
  7. beken
    beken Well-Known Member
    Jan 13, 2010
    1,405
    1,829
    Delta, BC
    There is no "speed" limiter, per se. But to keep you from blowing up your engine too easily, there is a fuel cut-off at a certain RPM.
    My car is an 05, so it might be different, but I found a rev limiter kick in at 7200 rpm. Redline on my tach is 6800 rpm. Do NOT try to hit it very often, especially if your car is bone stock. I only did it once and the engine still runs fine.
  8. ljmattox
    ljmattox Active Member
    Dec 28, 2011
    223
    123
    IT consultant
    St Louis metro USA
    I've hit the rev limiter / fuel cutoff a handful of times, usually on the 1-2 shift, or lack thereof :). 6500'ish rpm, thereabouts.
    MINIUSA posts the top speed of a new MCS Hardtop as 141mph, presumably they're allowed to achieve that? I've not had mine in controlled-enough conditions to verify...so far.
    I believe the fuel cut off & the speed limiter are two entirely different things.
    For what it's worth I hit the rev limit on occasion.:arf: These cars are built to do that. You will not hurt your MINI hitting it now & again.
    As far as the speed limiter goes I'd think the drag of the brick shaped MINI would keep me from reaching 135mph. That & not having a local track with a long enough straight.
