Exterior 1st Gen Spied: New Wing variation
Discussion in 'Tuning and Performance' started by Vader, Apr 24, 2010.
  1. Vader
    Vader New Member
    Oct 7, 2009
    45
    #1 Vader, Apr 24, 2010
    Looks like there may be a new, adjustable wing out there somewhere.
  2. Rixter
    Rixter Well-Known Member
    Jun 14, 2009
    1,230
    79
    Technology Architect
    North of the 49th
    Other than for the track, that's a bit much.
  3. Blainestang
    Blainestang New Member
    Jan 16, 2010
    216
    17
    It's even got little "canards" just above the beltline.
    So, is that carbon or plastic? I can't see the Carbon weave, so I'm assuming plastic.
    Also, how do these normally attach? It looks like it's stuck to the window and bolted to the base Cooper spoiler.
    Looks to be attached using the OEM mounting points with the downward legs attached to the back glass.
  5. Blainestang
    Jan 16, 2010
    216
    17
    So, it uses the OEM mounting points through the base Cooper spoiler (assuming that's what that is)?
    Sorry, I've never removed the OEM spoiler, so I'm kind of a noob to this discussion... and I'm brainstorming ideas for items I could make out of Carbon Fiber.
  6. Nathan
    Doesn't look that way.
    Looks like any OEM spoiler, either base or S, has been removed and the same mounting holes the OEM uses has been re-purposed here.
    The OEM mounts with 2 studs in the spoiler are bolted through the body.
    Ahh heck...I'll go pull mine for the umpteenth time and take a pic...
  7. Vader
    Vader New Member
    Oct 7, 2009
    45
    no more so than:
    coilovers
    any splitter
    pulley mods
    custom tunes
    etc etc etc
    Functional for the track...
    Bling for the street :Thumbsup:
    Under this cover, one per side....
    Is this...a stud in the wing and a locking nut to hold in place.
    If you note where the mounting points are on the spy shot it looks like a there is a recessed area in the portion that is flat against the body to countersink the head of a bolt. Being where they are located this looks like this wing is using the OEM mounting points.
  9. lotsie
    400
    stagehand/part time detailer
    Right here
    Should have used black bolts for the adjustable parts.
    Mark
  10. Blainestang
    Jan 16, 2010
    216
    17
    #10 Blainestang, Apr 24, 2010
    Hmmm... Still confused :D
    If I were to remove my R56's spoiler, the area underneath would no longer be flush with the roof, so a spoiler like the one above would have to come with a panel to cover that area, sort of like the CF JCW spoiler does:
    If it does, then "mystery solved"... otherwise, I'm still confused. :eek:
  11. Vader
    Vader New Member
    Oct 7, 2009
    45
    I 'think' the area underneath the stock spoiler is flush but when removed, you would have two ugly holes to cover if the replacment wing did not cover that area. By using the original mounting points, this wing takes care of it.
  12. Rixter
    Jun 14, 2009
    1,230
    79
    North of the 49th
    Nothing wrong with bling :ihih:
  13. goaljnky
    3,105
    392
    I would be interested in closer pics of those canards at the belt line. But for some reason I do like that wing...
    I really need to stop drinking this early in the day....
  14. Rixter
    Jun 14, 2009
    1,230
    79
    North of the 49th
    Perhaps you're still on yesterday's binge :eek6:
  15. lotsie
    400
    Right here
    Who would I drink with:(:lol:
    Mark
  16. goaljnky
    3,105
    392
    No... I distinctly remember waking up in bed without my clothes on... that means there was an acceptable break... this is definitely a new one... :D
  17. lotsie
    400
    Right here
    Do you remember how they were removed? If you do, it was not much of a binge:lol:
    Mark
  18. Blainestang
    Jan 16, 2010
    216
    17
    I think I'll need to see an R53 and R56 with the factory spoiler removed in order to help myself understand at this point.
    I'm just not understanding how the center area can be flush (and have a 3rd brake light) if the factory spoiler is removed and not replaced by a piece that comes with the new spoiler shown. :confused5:
  19. Nathan
    I have a sneaking suspicion this wing will make it debut at MOTD.
    Then again, I could be wrong...
  20. goaljnky
    3,105
    392
    I don't, but don't tell the wife. She finds that insulting. :devil:
