2nd Gen R56 Cooper S Sport button
Discussion in '2nd Generation: 2007+ R55 through R61' started by Mbroncosfan422, Jan 18, 2013.
  1. Mbroncosfan422
    Mbroncosfan422 New Member
    Dec 26, 2012
    13
    Mechanic
    Patchogue ny
    I have a 2011 mcs with 3000 miles on it and completely love the car. I read so much about the sport button being so great and fun which it's definitely fun but when I'm driving at around 65 and hit the gas with the sport off I feel it has more pull. Like I feel the turbo alot more at around 3000 rpm then I do with sport button on. At a light the sport button is better but again on open road it feels like I feel more torque when passing a car with the button sport off . I hope it's just me and not something wrong with the car lol.
  2. itsmewutup
    itsmewutup New Member
    Apr 11, 2012
    351
    67
    Must be just you lol. Its not really as noticeable til you've had the car awhile. That's my opinion anyway.
  3. DneprDave
    The sport button really doesn't affect the engine. It tightens The steering up and changes the throttle map. On automatics transmission cars, it also keeps it in a lower gear than usual, to keep the revolutions up for sportier driving.
    Dave
  4. Mbroncosfan422
    Dec 26, 2012
    13
    Mechanic
    Patchogue ny
    Whew I'm glad it's me and not the car lol. I have to say I only had the car for a month and its the most fun I ever had with a car. It makes driving fun like the first time u got your license .
  5. OhBe1
    OhBe1 New Member
    Aug 10, 2012
    16
    I'll guess and say that in normal mode, you feel the turbo spooling under load, whereas in sport the turbo is already spooled up. So you're probably not really faster, you just notice the bump.
    I've found it's easier driving in traffic in sport, throttle response being more linear. Looking forward to snow later this week & see how it does in the slippy stuff.
  6. CHKMINI
    ^^^^^what Dave says
  7. bmwr606
    bmwr606 New Member
    May 10, 2012
    62
    25
    actually, the throttle is more linear with sport mode off
    in sport mode, the throttle is progressive, ie you get 1/2 throttle when the gas pedal is only 1/4 of the way depressed vs sport mode off where you get 1/2 throttle when the gas pedal is depressed 1/2 way
    there is no hp or torque difference between sport mode on or off
    sport mode does change the amount of assist the power steering gives you and on the automatic transmission it does change the shift points higher and delays upshifts when you reduce throttle
    sport mode also turns on the pop/burble on lifted throttle
    scott
  8. Angib
    Yes, the sport button takes away any sensitivity of the throttle - just where you need to apply power gently. And the steering has sufficient weight in non-sport mode when driving quickly, so the extra weight doesn't improve anything.
    I reckon the button should have 'macho' on it, not 'sport', as I think its purpose is to make slow driving feel more butch.
  9. Metalman
    When I don't have the sport button engaged.... the throttle and steering is kinda dull... Not a comfortable feeling.....
  10. KittyMini
    KittyMini Club Coordinator
    1,183
    My sport button is my foot.
  11. DneprDave
    The steering doesn't feel any different to me, when I have my sport button engaged, but the throttle does and the automatic shifts differently.
    Dave
  12. mattkosem
    mattkosem New Member
    Aug 7, 2012
    9
    Wow, seriously? I find the difference immediately noticeable. If you really want to feel the difference, it is quite obvious if you toggle sport on while turning the wheel. It becomes heavier immediately.
    --Matt
  13. Metalman
    #13 Metalman, Jan 23, 2013
    Try toggling the sport button when you accelerate...
    Dullard..... The Stig.... Dullard..... The Stig.... Dullard... The Stig....
    I prefer the Stig button....:D
    Visual references...
    The Stig..
    Dullard....
  14. mattkosem
    Aug 7, 2012
    9
    Every time I have tried that, it has seemed like it did nothing around low/mid throttle until I released it and pressed it again.
    --Matt
  15. OhBe1
    OhBe1 New Member
    Aug 10, 2012
    16
    I prefer sport mode under most circumstances. Better throttle linearity (despite above comments), without the sudden turbo rush, especially beneficial in traffic. Easy to drive in slow, low-traction conditions, like up my driveway.
    As for steering, I think I'd like just a little more boost in sport mode.
    One last thing - not sure, but I think sport mode may delay brake assist, which is a good thing for me. have not done comprehensive tests, though...
  16. Little big car
    Little big car New Member
    Jun 20, 2012
    72
    Chesapeake, VA
    I like what sport mode does to the steering but for normal everyday driving I don't like how agressive it makes the throttle. With sport turned I find it too difficult to pull away from a stop smoothly without having to slip the clutch more than I would like. Clutches are expensive and a pain in the ass to change so I don't generally use it.
