Engine Drivetrain 1st Gen Cooper S Sprintex makes 272whp
Discussion in 'Tuning and Performance' started by Paul Webster, Dec 8, 2011.
  1. Paul Webster
    Paul Webster New Member
    Jul 2, 2009
    78
    31
    Well we've actually found some time to work on Old Red and find some hidden HP we started off with 246whp and have slowly progressed to below...we still think there's some more to be had, spec is;
    JCW stock head with stock valves
    Cat Cam
    Wossner 8.0-1 Forged Pistons
    1320 Conrods
    Mahle race bearings
    {{Megatron}} Manifold
    1320 de - cat
    1320 Quietflow cat back
    Sprintex Supercharger with 60mm pulley
    GRS TMIC
    1320 stand alone ECU
    Tesco 99 pump gas
    For more dyno sheets and pics of the cat back go to Blog
  2. Nitrominis
    Nitrominis Banned
    61
    Doing nothing
    Santa Cruz, CA
    Nice work guys!
  3. jiminni
    jiminni Well-Known Member
    262
    Ca.
    Very nice :cornut:
  4. BlwnAway
    BlwnAway Well-Known Member
    Nov 24, 2011
    474
    290
  5. AliceCooper
    AliceCooper Club Coordinator
    Mar 13, 2010
    643
    123
    CT Technologist
    South Florida
    impressive !
  6. Doggybags
    Doggybags New Member
    Curious to see what effect would a BVH have on these numbers. Any expectations on that end Paul?
  7. Paul Webster
    Jul 2, 2009
    78
    31
    We have a few BVH to try for 2012........everything we've tried so far has gained hp, so I'm sure there's a lot of heartache to come :)
  8. BlwnAway
    Nov 24, 2011
    474
    290
    You & me both, if I can get this damn misfire figured out, I hope to shed a little light on this subject.
  9. jiminni
    262
    Ca.
    Thought it was the cam?
  10. BlwnAway
    Nov 24, 2011
    474
    290
    It was, this is something new, (just call me Murphy) new cam took away ALL of my old problems, but apparently in the process of re-assembly I pinched one of the wires to my #4 injector, had to splice in the #4 550 pigtail, which fixed the misfire 95% (the miss went from really bad w/ a 0304 code and t/c & ses lights to now barely noticable at an idle with only a t/c light & 0304) so far I've checked or changed, compression, plugs, injectors and plug wires all seems fine. Today I'm going to try reading the faults with my F/A software (instead of my cheapo code reader) to see if it tells me any more info, look at some logs and check the current on my coil.
    As of now it's still a mystery, the car starts & idles perfectly for about 30 seconds, then you can hear the slightest misfire from the exhaust and the t/c light comes on w/ a 0304 code, the misfire is so slight that if it weren't for the light & me listening for it you might never know it. I really hate tracking down electrical sh*t.
    I Love Working On Cars.....
  11. jiminni
    262
    Ca.
    What about the coil? You sure the plug wires are ok?
  12. BlwnAway
    Nov 24, 2011
    474
    290
    Yup, changed wires, changed plug positions, changed injector positions, did compression check to help rule out qny easily apparent mechanical issues, what ever it is is a result of or relates to the original misfire with the pinched & bared wire, the first couple of drives before that were great.
  13. Metalman
    It couldn't be something as learned adaptations from the earlier problems. Maybe try canceling the adaptations if that hasn't already been done.
  14. BlwnAway
    Nov 24, 2011
    474
    290
    That is actually my next step, I was thinking along the same lines since the misfire doesn't start until the car runs for a few seconds. Will have to be tomorrow though, have to work again tonight.
  15. Nitrominis
    Nitrominis Banned
    61
    Doing nothing
    Santa Cruz, CA
    Any head JCW, BVH or stock with the exhaust improved will yields gains.
    Engines that get boosted like to get it out as fast as it goes in. :D
  16. PaImportTuner
    PaImportTuner New Member
    Aug 18, 2011
    16
    I would expect over 300 with the mods and charger. How much psi is the 60mm?
  17. Paul Webster
    Jul 2, 2009
    78
    31
    Its fluctuates on the 19/20 psi border..............we're still experimenting and it would be nice to see 300whp.
  18. BlwnAway
    Nov 24, 2011
    474
    290
    Give this man a cookie, I'll be updating my m/u thread as things progress if anyone is interested.
  19. Metalman
    I'm sorta partial to donuts.....:D
