1st Gen R53 Cooper S Starting Issues, gremlin junk.
Discussion in '1st Generation: 2002–06 R50, R53 & 2004–08 R52' started by Boxman, Aug 14, 2015.
  1. MCS02
    6,316
    ITS A BOY! Congrats! Say goodby to sleep.
  2. Firebro17
    ^^^ And your play money!
  3. MCS02
    6,316
    Hurry up get everything you want done to the Mini your window is closing FAST! :D
    But hay they are worth it. I wouldn't trade my 4 for anything.
    Well maybe a ............oh never mind:D
  4. vetsvette
    Congrats on your son.
  5. Boxman
    Boxman New Member
    Oct 1, 2012
    144
    34
    Technical Support Specialist
    Lebanon, Pennsylvania
    #65 Boxman, Sep 8, 2015
    Thanks everyone.
    Took the key apart on Sunday, soldered the unlock button because it somehow became dislodged.
    Didn't fix the problem but now I can press the unlock button, which is nice. Doesn't do anything aside from light my side markers.
    Doesn't unlock doors or anything of the sort. Battery inside the key was fine. Attempted to reprogram the key, that also failed.
    Does anyone know if the transponder chip is supposed to be soldered to the contact points underneath it? :lol: I also ordered a new key just cus.
    I'm going to go ahead with taking apart my steering wheel column and checking contacts in the ignition switch, and this so called "clock spring" I've been told about. :D I'll post more news this weekend.
    Tried checking the bcm, pretty dry as far as I could see.
    Still checking for bad grounds...
  6. Boxman
    Boxman New Member
    Oct 1, 2012
    144
    34
    Took a gamble, fixed the problem.
    Ignition switch was my culprit.
  7. 00Mini
    2,262
    Great to hear that your problem has been solved !! :Thumbsup:
  8. MCS02
    6,316
    Great to hear!!
  9. Firebro17
    Amazing! Glad that dimple fix was the cure!!
  10. myles2go
    myles2go Active Member
    May 7, 2012
    589
    223
    collecting a paycheck
    WI
    That's good news!
  11. ScottinBend
    Thanks for keeping us updated on this.
    This is one to add to the troubleshooting library.
