Engine Drivetrain 1st Gen Cooper S Stock to Pocket Rocket - Engine Mods
Discussion in 'Tuning and Performance' started by Ronbo, Feb 14, 2013.
    Ha Ha busted Jeff! :lol:
  2. wmwny
    4,040
    2,242
    Somehow, I just KNEW Mark would be nosing around....:ihih: It's tough to keep quiet for long in the MOM Club....:lol:
    You left a clue & Mark is sharp. Picked up your clue & did a Colombo on you. :D
  4. beken
    beken Well-Known Member
    Jan 13, 2010
    1,405
    1,829
    Delta, BC
    I started with a 22mm rear swaybar. Then added the Madness cold air intake, then 15% pulley, colder spark plugs, shorter belt. When the stock exhaust goes, I'm going either JCW or Miltek exhaust. Tuning would also be highly recommended.
    I would suggest, if upgrading the HP on your motor, you should also consider suspension to balance out the chassis/power combination. I would also consider better brakes if you have the stock brakes. Sometimes I feel I could use a bit more stopping power.
  5. astrochex
    astrochex New Member
    Oct 1, 2012
    15% reduction pulley (plugs and belt also), RMW tune, RMW street cam, larger injectors (e.g. 440s).
    I would not spend money on a catback or a CAI (a higher flow filter would not hurt though). With my few mods (15%, CAI, RMW tune, that are getting me 200hp with no increase in redline), I am leaving power on the table with the stock injectors.
    The money you have left over should be put into the suspension.
