Brakes Wheels 1st Gen Tires Stoptech over Wilwood
Discussion in '1st Generation: 2002–06 R50, R53 & 2004–08 R52' started by CurrysMini, May 2, 2011.
  1. CurrysMini
    CurrysMini New Member
    Mar 14, 2011
    27
    Corpus Christi, Texas
    Ok guys I'm in need of a big brake kit on the front two. Anyone have info on why the stoptech are almost a grand over the wilwoods? And if so is it worth it? I see the rotors are a little bigger. But do you get that much more stopping power for your buck?
  2. beaner
    beaner New Member
    44
    Call M/A vendor Todd at TCE. I asked him about StopTech, Brembo and AP before purchasing from him. He had nothing bad to say about the others. He explained the differences and left me to decide. Tires will almost always be the limiting factor in braking performance. I've been very happy with my TCE/willwoods on the street and doing DEs. They will remain as I transition to W2W racing.
  3. cct1
    The rotors on the stoptech are ALOT bigger--14 lbs worth of rotor.
    What exactly are you after? "Stopping power" isn't really going to be an issue; the brakes are only as good as your pads and tires; if you want to stop quicker, start with tires, the stock brakes are more than adequate for runflats on the street. If you're running R-comps on the track, then a BBK comes in handy--not because it's got incredible stopping, but because it's consistent; you won't fade your brakes as easily. And a BBK is easier to modulate on the track. Doesn't really come into play on the street.
    I run the TSW BDM kit, and it works great for the track (the R53 JCW brakes didn't, although that was without any cooling), it's there lap after lap. Around town (with a street pad), it's really not that much better than stock.
    So if it's a street car, I wouldn't bother. If you're going to hit the track, then a BBK may be worth your while. Talk to Todd.
    Actually around town or on the highway a BBK with a more aggressive track type pad compound is worse then OEM. These types of pads need some heat in them to work best and highway driving especially in wet conditions don't have the heat needed. Makes for interesting times on short exit ramps...
  5. Todd TCE
    Todd TCE Member
    The ST kits are 330 x 28 (or 12.97 x 1.10) vs the TCE Plus 4 at 13.1 x 1.10 actually. Both are about 14lb castings. The P3 at .810 (or optional .960 track use rotor) varies from 11 to 14lbs also.
    The reason I sell but perhaps 1 of the P4's a year is two fold; the car doesn't need this much iron to be effective 'cept for the the most extreme track day users and secondly, the wide rotor/caliper combo has a huge impact on wheel fit greatly limiting the choices to use without spacers.
  6. cct1
    Very true, but I don't run track pads on the street. Running a street pad on the BDM, for street driving (for me at least), it's similar to stock in performance. On the track, that's a whole different story. But you're right, running a track pad on the street isn't a great idea, but it doesn't seem to stop alot of people from doing it....
  7. Vader
    Vader New Member
    Oct 7, 2009
    45
    I will agree in principle but there are aggressive track pads with excellent cold characteristics. Wilwood PolyMatrix B pads for one. Their street downside is that when cold, they squeal like a banshee.
  8. quikmni
    quikmni Moderator
    Jun 6, 2009
    774
    174
    Aerospace Engineer
    Orcutt, CA
    When I did the research, I went with TCE/Wilwood 13 x 0.81 BBK mainly due to the cost v. benefit tradeoff. The Wilwood BBK satisified my goals at a lower cost. I have been happy with the Wilwoods for street and track. I swap pads for street and track use.
  9. CurrysMini
    Mar 14, 2011
    27
    Thanks guys for all the info. I'm going to start and track the car, thats why I was wondering about brakes. So when I start tracking it do I need to always swap out the pads everytime?
  10. Nathan
    It is a good idea to swap between a street and track pad. The Wilwood caliper is very easy to do that with. When I prep for a track day it takes about 20 min to swap out the tires and front pads. The pad swap is quick and easy.
  11. ScottinBend
    :Thumbsup:
    So many folks get a BBK for the wrong reasons. Remember that RSR uses the R53 JCW (R56) caliper with race pads and rotor.
  12. CurrysMini
    Mar 14, 2011
    27
    another quick question. What kind of tires should I be running for the track?
  13. cct1
    If you've never been on the track before, I'd recommend a high performance street tire--Hankook Ventus, Falken Azenis are two of my favorites--they're very, very good for the price.
    There are other good tires as well, some of them get VERY expensive, others are gonna chime in, but those are about the best "bang for the buck" tires out there. I run R-comps when it's dry, but I put on my street tires--Falken Azenis--when it's wet, and they are a TON of fun. Hankook's are actually higher rated, but I found the ratings after I purchased...
    Most important thing is to get quality seat time; as you do more, you'll go for more aggressive tires.
    It really is a learning process--there are different ways to get MINI around the track quickly; you have to find out what works best for you--that will dictate a ton of things...
  14. Todd TCE
    Todd TCE Member
    #14 Todd TCE, May 3, 2011
    While at the root of it I understand what you're driving at, but not everyone has the same reason either. I can't really think of any real wrong reason. Just different ones. The key imho is ending up with one that best meets your needs.
    Remember my earlier comment Todd's Rule of Three:
    1. Wheel fit.
    2. Intended use.
    3. Budget.
    Answer: Pick two.
  15. KC Jr 54
    KC Jr 54 New Member
    Jun 3, 2009
    402
    20
    Machine Operator
    Tyler, TX
    Nooot the greatest proofing of the statement. While RSR has awesome success w/ that set-up it is mainly due to the Chosen rotors ($700 option), which have a design that arent even found on most of the 'cost-effective' BBKs.
    Another HUGE point that should be factored into them using 'stock' calipers,; they are restricted to such per the rules they race under. I cant say they would go a different route if allowed to, but i imagine they would consider it.
  16. ScottinBend
    The point being that you don't need a BBK to be competitive. And yes they are req'd to run the stock JCW caliper, but they are also successful at it. The rotors are only part of the story, the pads chosen and the cooling available are a bigger part.
  17. KC Jr 54
    KC Jr 54 New Member
    Jun 3, 2009
    402
    20
    Machine Operator
    Tyler, TX
    1) They arent required to run the JCW specific caliber, it just needs to be AAAAA factory caliper. JCW was chosen by RSR for obvious reasons. (Just make the rules clear to people who dont know :Thumbsup:)
    2) It depends on the arena you compete in to say you dont NEED a BBK to compete. RSR competes against people on stock calipers as well.
    3) Agreed about the pads and cooling, but even though that is only part of the braking system and not a 100% cure all.
    4) If the r53 JCW caliper is soooooo amazing and all anybody needed, then why were the r53 Challenge cars spec'ed with AP Racing BBKs?
    The way i think of it; you enter into a knife fight and everyone is required to have only a 5" blade. You have that oooonnneeee guy who walks in with a 4' sword.... Now he may not win the fight, but his chances are A LOT higher then everyone elses. lol
  18. ScottinBend
    To the OP.......just make sure you are getting what you need and not what someone else is trying to sell you.
  19. CurrysMini
    Mar 14, 2011
    27
    Ok what about just changing out pads, rotors and stainless steel lines without going the BBK route? And if so which ones do you think I should buy?
  20. ScottinBend
    Depends entirely on what kind of driving you will be doing.
    Are you doing track days? What kinds of tires are you using? Mainly daily driver with the occasional weekend twisty excursion?
