1st Gen R53 Cooper S Strange, no ding-ding....
Discussion in '1st Generation: 2002–06 R50, R53 & 2004–08 R52' started by ScottinBend, Mar 11, 2014.
  1. ScottinBend
    So, you know that ding-ding-ding the car does when you first put the key in the ignition. Well for a few weeks now it just randomly refuses to ding-ding-ding. Starts fine, battery is new and fully charged. Odd thing that seems to happen with it is the airbag light seems to stay on longer after starting the car. Have not had any problems starting the car or while running.
    Any guess's?
    When you figure this out let us know so I can get rid of the ding ding ding.:devil:
  3. ScottinBend
    Ha....I simply use it as a timer to tell me the fuel pump is up and running :D
    I found your Ding-a-ling.
    [ame=http://www.youtube.com/watch?v=UaEC-lWSlmI]Chuck Berry - My Ding-A-Ling (1972) - YouTube[/ame]
  5. rkw
    rkw Well-Known Member
    443
    Actually no, I don't know it. I've never had a ding sound when I put the key in the ignition (I have a 2006 R52). Is it the same sound as when the drivers door is open with the key still in?
    As for the airbag light turning off slower, does it happen with both the dash light and the passenger occupancy light? If so, it might be the passenger sensor mat starting to fail (if your car is 2005+). This is happening to me a second time (first time years ago and fixed under warranty). Now it happens occasionally but the light can stay on for minutes.
    Also check the condition of your battery.
  6. rkw
    443
    So, am I the only one whose car doesn't sound the ding?
  7. Metalman
    Wonder if your ding-dinger was simply disconnected.
  8. ScottinBend
    OK....for all of you first gen guys, get in your car close the door and then put the key in. Does yours go ding-ding?
  9. Nathan
    Mine goes VROOOOOM
    Yes mine goes ding & then goes zoom.... :D
  11. rkw
    443
    It can't be "disconnected" -- all warning sounds are played by the computer on a speaker at the back of the speedometer. However, my car computer might have different firmware or settings.
    What does it sound like? Is it different from the door open or seatbelt warning sounds?
  12. Angib
    Hey at least you have gas/petrol engines that behave the same. My diesel needs pre-heating to start, but only in really cold weather, so it happens rarely enough that each time the engine won't turn over at once, I get caught out, thinking something's wrong - but then I see the pre-heater warning and breathe again.
  13. ScottinBend
    Same as the door and light ding. It starts dinging when you turn the key to position 2 (just before starting the engine). I think it dings 5 or 6 times then stops.
    Mine has suddenly started working just fine or it is simply saving up to really screw with me later.....:D
  14. Dave.0
    Yes:Thumbsup:
  15. MCS02
    Perhaps you've rang your ding ding one to many times!
    You don't want to go blind! :lol:
  16. MCS02
    If you put your seatbelt on before you turn the key on you don't get a ding. If leave it off and turn it on you should get a ding.
  17. Jason Montague
    :cornut: Or grow hair on your palms.:yikes::yikes:
  18. ScottinBend
    The initial problem was that the ding-ding wasn't happening every time. And the airbag light was staying on longer than usual. It is all back to normal now, or at least until it isn't.....:D
  19. MCS02
    Glad we could help! :lol::lol::lol:
  20. Dave.0
    Glad you found or got your Ding Ding back. Did your wife have it? :rolleyes::lol::lol:
