2nd Gen R56 Cooper S Street Mods 2011 MCS Hardtop
Discussion in '2nd Generation: 2007+ R55 through R61' started by kent kanipe, Jan 5, 2011.
  1. BThayer23
    Good catch. Yeah, the fronts don't gain much negative camber but the rears do when you lower the car. JCW springs apparently are exempt from this, btw - they don't lower the car enough.
  2. Rixter
    Rixter Well-Known Member
    Jun 14, 2009
    1,230
    79
    Technology Architect
    North of the 49th
    Too bad 'cause the JCW sport springs are the set I have. How does one measure the angle anyways, surely not with my kids protractor? :rolleyes:
  3. Jason Montague
    :lol::lol::lol::lol::lol::lol::lol::lol::lol::lol::cornut::cornut::cornut::cornut::cornut:
    I think that an alignment shop would have to do that for you but,there might be an easier way. Wait for one of hands on mechanical guys to come back up.:Thumbsup:
  4. BThayer23
    Have an iPhone? Download the Clinometer app and use a straight piece of wood across the wheel.
    [ame=http://www.lancerregister.com/showthread.php?t=284533]DIY Camber Gauge & Toe Alignment - Mitsubishi Lancer Register Forum[/ame]
  5. Rixter
    Jun 14, 2009
    1,230
    79
    North of the 49th
    That iPhone costs way more than my kids protractor. :eek6: Now that I know how it's being done, I'll see how I can improvise ;)
  6. AXO
    AXO New Member
    Nov 25, 2010
    91
    Wellington, Florida
    BT that is definitely Cool!
  7. Justa Jim
    Ben, how about the TSW springs? Would they require an alinement?
  8. BThayer23
    Mine required an alignment and adjustable rear lower control arms when I installed TSW springs, yes.
    I think my rear camber was around -2.5 to -2.8. I could feel it on off-ramps - it felt like the rear end was stuck to the ground. It was cool because the car felt impossible to spin, but that just meant it was primed to understeer and plow. And after I got the car properly aligned, I could take the same off-ramp a few mph faster.
  9. david in germany
    david in germany New Member
    Dec 15, 2010
    250
    After I installed my TSWs I had mine checked. All measured within factory specs and no adjustments were made.
    Did you have any issues prior to the TSW install?
  10. Justa Jim
    That makes me feel better. I am having them installed at MOTD, which is 9 hours (plus Dragon time) away from a alinement.
  11. BThayer23
    I have an R53 MCS with a sunroof and mine was out of spec. I don't know how that translates to R56, lighter R53 w/out sunroof, justacooper, etc. Talk to your installer.
  12. Metalman
    7,689
    From everything I've read, the slotted holes at the top of the front strut only give you about an additional .5 degree of additional negative camber if you remove that white plastic nipple (since you don't have adjustable camber plates it should be rather close to factory spec's). Also, from what I understand, negative camber doesn't really affect tire wear all that much on the MINI.
    What kills the tire is toe in or toe out. Perhaps your installer at the Dragon could do a quick measurement on the toe in - toe out spec. and get it close for your drive back for a proper alignment (perhaps the string method)?
    String Alignment Method for Toe-In
    DIY Alignment - Stringing your car - Honda, Acura Tech Website, tutorials, tuning and HOW-TO's. Drag racing, street racing, road racing - C-speedracing.com
  13. Justa Jim
    Thanks. My guess is WMW will take good care of me. :Thumbsup:
